Why don't we care about TIM (transient intermodulation distortion) anymore?
Music1969
Hi @amirm
I was searching TIM discussions and saw this:
The test is the old concern about transient intermodulation distortion (TIM) so a different animal than what we test or care about today.
Why don't we care about this test today, with amps?
It's essentially a solved problem. Much higher device bandwidths, more attention to circuit design, etc. have made slew-induced distortion one of those "solved" issues nobody talks about.
That said, I still like square-wave testing as a general thing, though Amir will (correctly) point out that it shows nothing on the vast majority of amps -- they are stable and well-behaved. The old square-wave plus HF signal test is interesting for the same reason but is unlikely to show anything on a modern amp.
IMO - Don
Me too, it is inevitable to verify stability into not only resistive, but also complex load.
BTW, DIM test is also not bad at all.
Is not that reluctancy to measure square wave response based on the fact that class D wideband measurements do not look nice because they are polluted by carrier frequency? I would bet it is the reason.
TIM measurements of cheap class D amps like TPA3255 look pretty ugly. Same applies to CCIF IMD 19+20kHz distortion at higher level. So these measurements are not done with the comment that they are old fashioned or unimportant.
http://hifisonix.com/wordpress/wp-c...ouglas-Selfs-8-Distortions-and-a-Few-More.pdf
#9: Slewing Induced Distortion and Transient Inter-modulation Distortion Problem Magnitude: Only occurs on fast rise time music signals, and generally not an issue on modern amplifier designs due to awareness of mechanisms that cause it Cure: Ensure amplifier slew rate is at least 2x to 3x the worst case input signal rise time and/or limit the input signal bandwidth such that it is 2 to 3 times less than the power amplifier feedback loop unity gain frequency which is typically around 850KHz Effectiveness of Cure: completely avoidable
Much more. At least 5x better 10x. Otherwise you will see it at 19+20kHz distortion as well.
However, just measured a step (square) response of AIYIMA A07, 4ohm load, the best case without FR peaking. If this was a linear amplifier, I would immediately throw it out into the dustbin. However it is class D, so who cares? It will be said it is unimportant. See LC resonance, and also see very low slew rate.
Edit: got rid of the SMPS spikes (shield currents), this is the new graph otherwise same
However, just measured a step (square) response of AIYIMA A07, 4ohm load, the best case without FR peaking. If this was a linear amplifier, I would immediately throw it out into the dustbin. However it is class D, so who cares? It will be said it is unimportant. See LC resonance, see SMPS spikes in the bridge branches and also see very low slew rate.
That's pretty ugly... The SMPS spikes are not too large, and very high-frequency, so vexing visually but probably inaudible. The output filter ringing at 50 kHz and what, 4 Vpp?, is more concerning to me. Not a lot of power but within range of some tweeters and low enough to modulate others. Fortunately not all class D amps look this bad. For this one, the dustbin seems rather appropriate.
But aren't those oscillations there only because they are excited by a square wave, which has contents at 50 kHz?
[Edit] And the summed signal was pretty smooth.
Not my data... A valid point. I would not say "only"; I would say they are more prominent due to the square (HF) driving signal, but they will be there at some level whenever there is enough HF energy in the source to excite them. In the real world, most music and such has such low very HF (for audio) content that it's probably not a problem but that is purely speculation on my part. Movies, particularly ones with gunshots and explosions and such, are likely to excite such ringing as well, though how again I could not say at how high a level.
The ringing is in-phase and so the net bridged output rejects most of it (cancels common-mode distortion/ringing). If you use it non-bridged (if possible, I know nothing about this amp) it would be more a concern to me. Audible? Who knows...
In any event there are other, better amplifiers class D and otherwise, and I have no dog in this hunt (I have class AB and D at home but have not done rigorous measurements of any of them).
They rely on cancellation of the 2 branches of the BTL output. If you make a simulation, the filters behave exactly as measured. Simply LC with R damping. Edit: the SMPS spikes fixed (shield HF currents)
@NTK the LC resonance excitation depends on input dv/dt of course. But it starts at smaller dv/dt, with smaller amplitude. It is inherent to LC outside FB. There is a trade off between -3dB filter frequency and damping of the step response. Just physics.
Hypex NC 400 step response into 10 ohm load. The oscillating response is still there, though lower in amplitude. Plus carrier freq.
The class D is specific of its own. These are "unpopular" parameters of the class.
TIM may have been solved in most cases. It reminds me of my job at Polygram as junior balance engineer forty eight years ago..
Polygram mixing consoles were constructed using large numbers of early opamps designed for telecommunication by Philips.
These opamps had an open loop gain of around 100 dB. That was much more than needed in the equipment we used.
Between 50 and 80 dB negative feedback was used to reduce that amount of gain.
That amount of feedback resulted in massive TIM which was noticed by using the recently constructed power amp I designed.
Listening tests revealed the TIM.
The power amp I designed applied no more than 32 dB feedback in multiple loops.
The discovery of TIM in Polygram mixing consoles did not make the Audio Engineering Dept. of Polygram happy.
They had to start from scratch to design new consoles for the Wisseloord studio that was being constructed.
The mixing consoles from the next generation sounded excellent and had excellent ergonomics.
I question the last two recommendations in the list.
Application of massive amounts of negative feedback indicates the basic design of the amp is not sound.
Large amounts of feedback will induce stability problems especially for power amps with a complex load.
The more feedback the better it sounds provided it is never less than 30 dB at any audio frequency is definitely not something I would advise.
I would like to point to the importance of Nyquist diagrams when negative feedback is applied in power amplifiers.
Negative feedback is not a magic potion that cures basic design flaws.
The proof is in the pudding. Anything wrong with the latest batch of Purifi EIGENTAKT amplifiers Bruno Putzeys developed?
His second last point didn't exactly say successfully designing amplifiers utilizing huge amounts of feedback is easy.
