Hello,
I am using a pair of Neumann KH-120 in my main system.
They stand in an ordinary room, with not even a carpet or curtains, and a large window near the speakers. The decay time measured at the listening position, from the speakers, is 0.45 s at 500 Hz and 0.5 s at 2500 Hz.
The listening distance is 2.1 meters.
I've been listening to them for 3 years and I don't imagine changing for anything else ! Everything sounds good with them.
The user manual says that for an ordinary room, it is better to set the treble control to -1 (and 0 for a well-treated room). I came to the same conclusion by ear.
Unfortunately, the room has very strong low frequencies resonances. So I had to use an equalizer to deal with the low frequency part. Here is a multipoint measurement around the listening position, with VAR smoothing :
Here is my correction :
And here is the result after equalisation, moving microphone measurement, from the listening position, 1/48th octave RTA :
The level of the low frequency target was extremely difficult to find. It took about two years to find something that sounds neutral. As you can see, the resulting curve looks strange. The 200 Hz region is nearly at the same level as the 600 Hz one. Then, starting from 100 downwards, the target level decreases ! It looks strange, but sounds good.
The upper part of the frequency range, from 1 kHz upwards, is uncorrected. It looks a bit uneven. This is probably caused by the fact that the speakers stands are too short. The speakers stand a bit below the listening position. From the listening position, I can see the top side of the speakers.
Here is a windowed measurement taken with the microphone 70 cm from the speaker.
Green : in the tweeter's axis
Red : midway between the woofer and the tweeter
Light blue : in the woofer's axis
Dark blue : midway in height, but off axis, to the left.
Unsurprisingly, the worst curve is the one that is off axis vertically (light blue).
Listening impressions
The overall feeling is that all frequencies are balanced, with just a slight lack of bass (which is done on purpose by my EQ).
I went to an organ concert in the church of my town, and they were selling a CD with recordings of this organ. When I went home, I listened to the CD, and the sound was exactly the same as what I had heard several minutes before in reality, except the lack of low frequencies.
The result is extremely good with choirs, and also with acoustic drums.
Choirs and symphonic music are said to be very demanding, but they are no trouble for the Neumann KH-120. They are even the musical styles that sound best with these speakers !
Here is an example of recording that sounds incredibly good on my system : listen to the last part, with the choir, starting from 22:45 :
The style that is more difficult to reproduce is techno music, because, in spite of a careful equalization, the low frequencies of the electronic drums don't sound very good in my listening room.
There are also some frequency peaks around 200 Hz that depends a lot of the exact listening position, and that are different on the left and right channel. I could not equalize them properly. But they come from my room, not from the speakers.
Other speakers that I have listened to in the same configuration :
Kef R300 (around 1300 euros) : coloured sound. Annoying peak of about + 5 dB around 700 Hz. Lack of high frequencies. Female vocals sound recessed. Excellent low frequency extension (until around 30 Hz thanks to the awful resonances in my room). I didn't keep them long. They gave me no pleasure listening to music. I always had the feeling that the leading melody was too far away, with the bass in front of it.
Dynaudio Gemini with +1.5 dB tweeter built-in (between 1000 and 1500 euros). Too bright sounding.
Boston A26 (around 400 euros). Nice sounding, but the medium frequencies are not natural.
JBL 305P mkII (220 euros). Too bright, with medium frequencies not sounding natural.
I have then measured the JBL, and, unlike what I have read about them, I found no trace of any resonance in the medium frequencies, but rather a sharp abnormal transition at 1500 Hz, as if the tweeter was playing too loud comparted to the woofer, and also a huge amount of harmonic distorsion (1% for harmonic 3 alone, from 300 to 600 Hz, plainly audible while they are playing the test signal).
The strange thing is that, with my listening position being vertically off-axis, the JBL showed a perfectly consistent behaviour between the anechoic windowed measurement and the MMM measurement from the listening position, while the Neumann did not.
View attachment 33995View attachment 33996
