I didn't find that to be the case for me.I find it more of a challenge to integrate a subwoofer into a smaller room for nearfield. Not impossible just more time consuming.
You are more skilled than I am. I notice smaller rooms tend to have stronger, more isolated modes.I didn't find that to be the case for me.
I don't get the connection between "smaller rooms" and nearfield listening. Nearfield listening is not a "small room" thing. It's btw also not about listening at a desk. My living room with my nearfield setup is about 350 square feet. My listening distance is about 2 to 3 feet and no, I'm not sitting at a desk with a computer. I don't understand where that common misunderstanding comes from.I find it more of a challenge to integrate a subwoofer into a smaller room for nearfield. Not impossible just more time consuming.
You could be surprised if you try (for free) nearfield in a big room seating near the centre of the room, the sound will fill the room and give you a spectacular sound field both in depth and width up to the limits of the room, the bigger the better.I get nearfield is just distance, I guess my mind sees a large room and doesn’t want to waste it when you can sit farther back and get more scale out of it.
Wikipedia said:Yes, a widely accepted definition exists based on the ratio of direct to reflected sound: nearfield listening occurs when the listener is positioned close enough that the direct sound from the speakers dominates over sound reflected by room boundaries like walls, floors, and ceilings.
This technique was developed by audio consultant Ed Long and is characterized by placing speakers very close to the listener (typically 4 to 5 feet away) to minimize room acoustics interference. The primary goal is to hear mostly what is coming from the speakers rather than the surrounding environment, effectively creating a listening experience similar to headphones but with a physical soundstage.
"Nearfield" loudspeakers are those which are intended to be three times closer to the listener than the nearest hard surface. Nearfield listening reduces echo, and reduces the impact which poor room acoustics may have on sound.
The lower the frequency also makes it more difficult since the room dimensions are shorter, making the bass standing waves a higher bass frequency that appear more in the music (compared to lower bass) and seem louder.I find it more of a challenge to integrate a subwoofer into a smaller room for nearfield. Not impossible just more time consuming.
On the one hand, it's obvious and a bit tiresome to keep mentioning it over and over again for decades. Thank you for taking the time! On the other hand, the confusion persists. And will continue to persist, despite your excellent post.nobody has pointed out that
So far nobody has pointed out that there are two meanings for "nearfield/farfield". See @NTK post here for a better explanation.
I think you have shared info with better definitions, compared to the layman sources I used. But I would bet the definition of nearfield will change due to popular misuse, if it has not already.On the one hand, it's obvious and a bit tiresome to keep mentioning it over and over again for decades. Thank you for taking the time! On the other hand, the confusion persists. And will continue to persist, despite your excellent post.
when my uncle bought me my first nice stereo system fifteen years ago, he chose the andrew jones speakers, as well. they sound great! people are snobbish about them because they are so inexpensive, but i like them a lot.I use a pair of the old Pioneer Andrew Jones bookshelf speakers on my desktop. They sound great, matching Amir's review. I got them at Fry's on a $69 a pair closeout sale when there was a Fry's. In the living room or other parts of the house near field is impractical.
when you get it right, the phantom center image is very satisfying with a near-field setup. i have a pair of small genelecs on my desk and on the rare occasions when i get to listen to them, it's like going to the movies. i love it.I'm using studio monitors as computer speakers for music and PC gaming so near field is the way to go in my case. My smallish square-shaped, untreated room makes my speakers sound terrible in mid and far field. With near field, the direct sound coming from the speakers is all I hear.
I also don't need powerful amplification because I can already get higher SPL in the near field by virtue of being closer to the speakers.
All that said, I've learned that speaker selection and positioning becomes incredibly important for nearfield to get the most out of it. Things like having the speakers equidistant to each other and with the listening position. Having proper toe-in and speaker height based on the guidelines provided by the manufacturer. All in order to achieve a good stereo image/phantom center and the summing of the speaker drivers as designed.
