Why doesn't nearfield listening get more love?
Sitting at a desk is not relaxing to me and it'd be difficult to position my speakers close to me in my listening room.
Also, I don't enjoy it. Makes everything seem miniature as if tilt–shifted.
Just some thoughts, psychologically, if you already have a large and expensive system, there's a very good chance you wouldn't be very interested or receptive in nearfield, sunk cost fallacy and all. Similar too for prestige & impressiveness, if looks, prestige, etc., are important, then small black boxes likely aren't very attractive. Obligatory car analogy; if you own a 2M Pagani or Bugati, you might not be interested or receptive to something like a Superlite SL-C or Ultima RS...
Thinking back, years ago, at a hifi trade show, one of the best listening experience I had was from what I think were studio monitors in nearfield (maybe midfield?) coupled with fancy DSP... Can't recall brands or models, but I thought at the time this DSP was too expensive ($2500?) and eventually cost will go down and DSP will completely take over, which has yet to happen. But again, this was a relatively affordable nearfield system, pretty much just thrown into a very large room, cost a fraction of what everything else cost, sound was superb, probably best of the show. Total cost was probably like <7.5k
I was thinking why it's less distracting for me to have small speakers with ~40-50Hz response in nearfield rather than full sized system. And basically eliminating room aberations is so much more important than the <50Hz. And most in room systems will, typically, have wonky <100Hz bass & much worse FR due to room interaction. In a perfect world with unlimited $$$, large expensive speakers in a dedicated room with room treatment and DSP & perfectly sounding setup, sure, it would likely win out over nearfield, but how easy is that to achieve? How many people have access to that? I don't think I can reiterate how much PITA it is to have proper well setup system with flat FR in a room, or how much more expensive it would be vs nearfield or midfield studio monitors...
I think a proper system (flat FR) isn't even possible in most small/medium room for multiple listeners. EQ/DSP just ends up messing up things more for a 3rd or 5th listener, and room is so damaging for FR, and listening position is so important, not to mention being in the sweet spot, 3rd or 5th listeners aren't getting a proper experience... Not to mention speaker position and listening positions will almost always be a compromise, unless dedicated room with room treatment, which again most don't have access to.
TLDR; Most people don't have access to dedicated well setup system, so for most hoping to achieve 'maximum sound quality', nearfield would likely be the best bet, depending on how you define 'maximum sound quality' ;)
In my case it is a step towards relative minimalism, and back to stereo. I had an Atmos system before, which I've sold with the whole house, remigrating from Germany to my native Poland. So i thought, monitors were the least cumbersome, and flexible (adding subs was an option, no amp worries etc.). Ended up with two pairs of monitors for two rooms (see below). Absolutely happy with them. But, WAF is no issue.
Reactions: GM3
Just curious why so few people seem to focus or prefer nearfield listening to traditional setups. AI answer spoiler below, but the AI summary is good:
(AI) Nearfield typically gains:
- much lower room influence
- higher clarity
- more precise imaging
- and lower required playback levels for the same perceived loudness.
And deriving from that, I'd add
- lower cost, since you don't need gigantic speakers to energize an entire room, you can get away with much smaller and cheaper speakers, most often active & powered.
- don't need a dedicated listening room or even room treatment.
- much better solution for everyone around you (noise levels; neighbors, for apartments or condos, etc.)
- much easier to optimize (DSP or EQ) given the more static listening position and speaker position. Plus you can easily push your chair back and forth for different soundstage options.
- practicality aspect, as most people have a computer setup and the screen and computer contain basically everything to play music and video. Everything is centralized and easy to access. No need to get up to switch CDs or records, entire library is easy to access, no need to buy a streamer or tablet to switch songs or whatnot... Plus speaker placement and listener position (triangle) is basically free.
Most audiophiles lean toward traditional farfield setups because they like a big, room‑filling presentation and the sense of “listening into a space,” whereas nearfield feels more like having the music right in their lap, which many find too intense or “unnatural.”
Psychoacoustic and preference reasons
  • Many listeners associate realism with a broad, distant soundstage like a good concert‑hall seat, which is more easily mimicked by sitting farther from the speakers and letting the room contribute some spaciousness.
  • Nearfield can feel almost headphone‑like: very direct, very close, and sometimes intrusive to people who prefer the music to be “over there” instead of “right here” in their personal space.
Room interaction and “big sound”
  • Farfield listening uses room reflections to add apparent size and depth to the soundstage, so the system can feel larger, more enveloping, and more “live,” even if the trade‑off is less precision.
  • Moving the chair closer often reduces that reflected energy, which improves clarity but can shrink the perceived stage and sense of ambience that many audiophiles value.
Bass and physical impact
  • Placing speakers and listener farther apart and closer to room boundaries usually boosts bass through room gain and modal interaction, which can give a more powerful, “full‑range” impression.
  • Nearfield setups often sit away from walls and corners, so they can sound leaner unless carefully supported with subwoofers or EQ, which some audiophiles interpret as less satisfying.
Gear, ergonomics, and culture
  • Much traditional hi‑fi gear and furniture is designed around sofa‑distance listening, so rooms, racks, and aesthetics all nudge people toward farfield rather than a desk‑style or close‑chair layout.
  • Many speakers are voiced and engineered assuming some listening distance; up close, driver integration and vertical lobing can become more problematic, making nearfield less forgiving unless you use monitors designed for it.
Summary of what nearfield “costs” and “gains”
  • Nearfield typically gains: much lower room influence, higher clarity, more precise imaging, and lower required playback levels for the same perceived loudness.
  • It typically costs: some perceived spaciousness, some bass weight, and the relaxed “sit back in the room” experience that a lot of audiophiles emotionally associate with high‑end listening, which is why it remains a minority preference despite its technical advantages.
And to respond to AI. Most music these days doesn't correlate to reality. Unless you're listening to an orchestral recording, most records are mixed and so there's not 'real life' correspondence that you're trying to match. So sure, the soundstage will be smaller, but what does that matter when things don't correlate to real life? And even speakers & rooms can't correlate to reality, given different recordings contain different things; ex; jazz band vs orchestra vs single singer or guitar... What works for orchestra results in giant singer or giant guitar?
Nearfield basically sits between traditional room speaker setups and headphones. It doesn't have the downsides of headphones (wires, comfort, heat, in your head soundstage, etc.,). It doesn't have the biggest speaker drawbacks (nulls/boosts in FR because of room, disturb neighbors because enjoyable SPL, $$, no dedicated room required, no wires, amps, streamers, etc.).
I'm a bit surprised it's not the prefered listening method for most people!
I personally find nearfield listening much less enjoyable since there's almost no envelopment, and less width and depth to the stereo images.
Note that in the low-frequencies the room impact exists equally in nearfield and farfield.
At higher frequencies the ratio of direct vs reflected sound is indeed higher in nearfield, but I'd argue that is actually the drawback of nearfield listening for music enjoyment - it decreases the feeling of envelopment.
In summary I definitely prefer to listen to music for enjoyment on my living room system, but I prefer to use my desktop system for tasks that require detailed critical listening - like audio production.
Reactions: GM3
I'll just add that I am a big fan of nearfield subwoofers and built one to fit under my seat.
Reactions: GM3
I think nearfield gets lots of love here, just take a look at the threads of tiny speakers, they grow enormous, specially when they are well made.
In general, nearfield is considered a tool, an activity no different than if you were working at your office, etc.
And then is the "as intended by the artist". Sell is done in the control room, despite the mix or music.
Strangely, the classical you mentioned (my music) may require some extra stuff but not that you can;t enjoy it nearfield as well.
ll it needs is a speaker with some meat at the midbass and without pronounced highs. Our brain takes over for the rest of the it.
It's surely more enjoyable (for me) at 3 meters, bigger soundstage, depth and height and the works but nothing wrong if the circumstances don't allow for that.
Well, I am one of those who is forced to sit in front of a computer screen for hours. Having the ability to listen to high quality music is AWESOME for me, makes that ordeal much easier and even fun (I like my work).
And I enjoy the little stage in front of me that I can get from my little active speakers, and if I need more immersion I switch to headphones and *everything* is there.
But of course my music shrine is my fav. Music, a book, two cats next to me and a glass of wine... daily heaven.
I have two systems in one room: large floorstanding speakers and bookshelf speakers connected to my computer. I listen to both, depending on my mood and state of mind. I didn't specifically aim for a cloned sound. They sound different. I like both sound sources.
I don't have a desktop system; I listen to a far-field system at my computer desk. Or anywhere else in the room.
Yes, you have to take precautions against room modes and use larger speakers; room acoustics also matter.
But a nearfield system just isn't desirable :cool:
Reactions: EJ3
I listen at 5 feet with Genelec 8361a's. If I could manage it, I would listen more closely to increase the direct vs indirect. Those beautiful point source center images are desirable to me.
I like generally midfield which for me is between seven and 8 feet from my loudspeakers usually closer to seven (right now I’m 7 feet from my loudspeakers).
The reason I personally don’t like Nearfield:
It generally forces the speakers to be closer together and I like the sensation of a big wide presentation.
I have found that when I get too close to near field the sound takes on more of a
“ headphone like” experience. It starts to sound a bit more weightless. The further I get back from the speakers the more live and energetic, dense and palpable the music sounds, closer to listening to real musicians.
But the closer I get to my speakers more nuance I hear about the recording and the timber of the instruments and the more immersive. So I happen to have found between seven and maybe 7.5 feet, with my speakers spread about 8 feet apart, to be the sweet spot in my room for the best of both worlds.
My journey come from headphone - nearfield to midfield, and I greatly prefer midfield as I like the holographic presentation, especially for classical music. Nearfield is ok for me when I play pop music. Headphone is great for vocal only, but no go for classical music in my book.
This "headphone-like" experience is probably the more correct variant (less room influence) but can (and mostly will) be less pleasant, for, well, the same reason.
Reactions: EJ3
The closer it gets, the more it resembles headphones, which of course begs the question; why not use headphones instead?
Good question... If I knew it will be this way, I really might be tempted to have headphones only in my desktop setup. Would save money and work (room treatment). But I didn't know :)
And, loudspeakers still provide more comfortable listening than any headphones or IEM.
I enjoy both nearfield listening when I'm at my desk and midfield when I'm in my lounge. I prefer the latter as I find it more immersive, but I appreciate the former as well.
The ratio of my listening is close to 2:1, favoring midfield. However, that can swing the other way if I'm busy with work.
I do use a touch of DSP for nearfield, to widen the soundstage. Otherwise, at such a short distance away from the speakers, it's like listening with headphones. There's nothing particularly wrong with that, but it's not the experience I wish to have at my desk.
Yes, I use headphones at the desk for music—no loudspeakers there currently. Which has the side effect of delineating relaxed listening in a bigger space from work-adjacent stuff.
Large enough systems with WG in a decent room from a distance of several meters are somewhat and partially reminiscent of headphones. Large headphones. Not at all like headphones :cool:
You can see it that way.
The border when it becomes more headphone-like is fluid.
An extreme example. ;) :D :
For my part, I have never liked IEMs. When I'm out walking, exercising, I use lightweight retro Bluetooth headphones instead:
In my room 0.5 meters/1.64 ft listening distance to my speakers, then I might as well use headphones.
I may have missed this in the thread, but has it addressed or emphasized the advantages of point source speakers for near field listening?
Intuitively, if I were to have speakers placed at 1-0.5 meters/3.3-1.64 ft, I would want some good point source speakers.:)
