Why doesn't nearfield listening get more love?
GM3
Canuckistan
Just curious why so few people seem to focus or prefer nearfield listening to traditional setups. AI answer spoiler below, but the AI summary is good:
(AI) Nearfield typically gains:
- much lower room influence
- higher clarity
- more precise imaging
- and lower required playback levels for the same perceived loudness.
And deriving from that, I'd add
- lower cost, since you don't need gigantic speakers to energize an entire room, you can get away with much smaller and cheaper speakers, most often active & powered.
- don't need a dedicated listening room or even room treatment.
- much better solution for everyone around you (noise levels; neighbors, for apartments or condos, etc.)
- much easier to optimize (DSP or EQ) given the more static listening position and speaker position. Plus you can easily push your chair back and forth for different soundstage options.
- practicality aspect, as most people have a computer setup and the screen and computer contain basically everything to play music and video. Everything is centralized and easy to access. No need to get up to switch CDs or records, entire library is easy to access, no need to buy a streamer or tablet to switch songs or whatnot... Plus speaker placement and listener position (triangle) is basically free.
Most audiophiles lean toward traditional farfield setups because they like a big, room‑filling presentation and the sense of “listening into a space,” whereas nearfield feels more like having the music right in their lap, which many find too intense or “unnatural.”
Psychoacoustic and preference reasons
  • Many listeners associate realism with a broad, distant soundstage like a good concert‑hall seat, which is more easily mimicked by sitting farther from the speakers and letting the room contribute some spaciousness.
  • Nearfield can feel almost headphone‑like: very direct, very close, and sometimes intrusive to people who prefer the music to be “over there” instead of “right here” in their personal space.
Room interaction and “big sound”
  • Farfield listening uses room reflections to add apparent size and depth to the soundstage, so the system can feel larger, more enveloping, and more “live,” even if the trade‑off is less precision.
  • Moving the chair closer often reduces that reflected energy, which improves clarity but can shrink the perceived stage and sense of ambience that many audiophiles value.
Bass and physical impact
  • Placing speakers and listener farther apart and closer to room boundaries usually boosts bass through room gain and modal interaction, which can give a more powerful, “full‑range” impression.
  • Nearfield setups often sit away from walls and corners, so they can sound leaner unless carefully supported with subwoofers or EQ, which some audiophiles interpret as less satisfying.
Gear, ergonomics, and culture
  • Much traditional hi‑fi gear and furniture is designed around sofa‑distance listening, so rooms, racks, and aesthetics all nudge people toward farfield rather than a desk‑style or close‑chair layout.
  • Many speakers are voiced and engineered assuming some listening distance; up close, driver integration and vertical lobing can become more problematic, making nearfield less forgiving unless you use monitors designed for it.
Summary of what nearfield “costs” and “gains”
  • Nearfield typically gains: much lower room influence, higher clarity, more precise imaging, and lower required playback levels for the same perceived loudness.
  • It typically costs: some perceived spaciousness, some bass weight, and the relaxed “sit back in the room” experience that a lot of audiophiles emotionally associate with high‑end listening, which is why it remains a minority preference despite its technical advantages.
And to respond to AI. Most music these days doesn't correlate to reality. Unless you're listening to an orchestral recording, most records are mixed and so there's not 'real life' correspondence that you're trying to match. So sure, the soundstage will be smaller, but what does that matter when things don't correlate to real life? And even speakers & rooms can't correlate to reality, given different recordings contain different things; ex; jazz band vs orchestra vs single singer or guitar... What works for orchestra results in giant singer or giant guitar?
Nearfield basically sits between traditional room speaker setups and headphones. It doesn't have the downsides of headphones (wires, comfort, heat, in your head soundstage, etc.,). It doesn't have the biggest speaker drawbacks (nulls/boosts in FR because of room, disturb neighbors because enjoyable SPL, $$, no dedicated room required, no wires, amps, streamers, etc.).
I'm a bit surprised it's not the prefered listening method for most people!
I use a pair of the old Pioneer Andrew Jones bookshelf speakers on my desktop. They sound great, matching Amir's review. I got them at Fry's on a $69 a pair closeout sale when there was a Fry's. In the living room or other parts of the house near field is impractical.
- higher clarity
I plead innocent :) (see sig.)
Many prefer "the old ways", some perhaps do not know. And, for a single it is easier than with wife and kids.
Reactions: GM3
All the advantages that you mentioned are real. However, the criticisms I've heard include, "Can't party to that", "Ain't no bass", and "How are all four of us gonna hear the same thing?" ... which are all legitimate.
I think the biggest disadvantage to nearfield listening is that most "regular" speakers ... even small ones ... are voiced for listening distances of 6 feet and more. For the nearfield, this means that the treble can be too "hot", and deficiencies in driver summing can cause listening position to be super critical, as in "head in a vice".
Care in choosing speakers can ameliorate these characteristics, but the vast majority of listeners simply take the easy route. I can't really blame them.
If your speaker is 4' tall, with the top driver being so far from the bottom driver, as in my case (MartinLogan 60XTi), I think that can affect your perception of the sound coming from one place. But if you say, well, the speakers can be smaller, then you run up against how smaller drivers sound vs larger drivers.
Reactions: GM3
I prefer the sound "in a room", and you don't have to sit precisely in one spot.
"Real music" (live) is performed in a space where the room reflections are an important part of the sound. We don't get anything like that in small home environment but most people still like to hear some room sound.
Some people prefer a "dead' room and more "studio-like" sound. Near field listening may be OK for that kind of sound.
You still have the same standing wave issues in the bass range.
Respectfully, I don't participate in threads from OPs who feature AI slop, which I consider pernicious. Forums for me are for the voices of human beings, not evil robots that scrape and plagiarize the words of human beings.
The topic appeals to me, but I'm out.
No worry. Not to start a philosophical discussion, but some parts of my question were already answered, so providing part of the answer of the topic that was to be discussed only seemed logical, saves everyone time and energy! That's why it was spoilered & identified at such. (2 references AI used for its answer: https://pmamagazine.org/nearfield-listening-what-you-hear-may-surprise-you/ or https://www.soundstagexperience.com...iews-menu/552-the-joys-of-nearfield-listening).
I think the biggest disadvantage to nearfield listening is that most speakers ... even small ones ... are voiced for listening distances of 6 feet or more. Treble can be too "hot", and deficiencies in driver summing can cause listening position to be super critical, as in "head in a vice".
Yeah for me FR accuracy (less room modes) by far outweighs bass response (<40-50Hz), which are anyhow a huge PITA, even sometimes downright impossible, to get right in a room...
6 feet seems far for nearfield, I'm about at 1m, and seems like most smaller (4-5 inch drivers) monitors recommend 1-1.5m. And for some reason, headphones and speaker setups seem more offensive in their FR aberrations for me. I'm using relatively cheap Edifier R2000DB, (measurements, blocked ports for me which helps for bass boost) and for most speaker setups and headphones, for dedicated listening, often seem to want to reach for either EQ or reposition the speakers because of some flaws I'm hearing... Yet for the cheap Edifiers in nearfield, it sounds fine, and I don't get the same urges to try to fix stuff... *shrug*
I think nearfield is just more accurate relative to FR. Thinking back, last time I played around with speakers, many just ended up way too far into the room, then their low end suffered a bit because of it... So always just compromises, and can never get things as perfect as I'd like. Loudspeakers are such a PITA to setup in room...! Nearfield are so much easier, but maybe I'm just more sensitive to such FR aberrations! (If I don't care about <50Hz for nearfield, one less thing I have to fix!)
For me, preference is for mid-field as the overall soundstage size and perspective is closer to life-size for a lot of music when speakers are placed 2.5-3.5m apart. Far-field is ok too as long as the direct to reflected ratio is not too low. Mostly I like a sound stage that is wide and images with some height where room acoustics and recording information allows it.
For critical listening deep into a mix then headphones and nearfield monitors are best, but I enjoy it less than when a bit of room sound is added in, and speakers set wide apart.
The majority of my close listening is nearfield, in my workroom system. My other setups around the house are normal midfield type. Both sound good, I have just spent a bit more time perfecting my nearfield system/component rotation as it does get the bulk of my listening time, these days. The other systems are more for casual/background use.
The closer you get, the more important head position is to correct imaging.
Prefer midfield myself as I am nerdy enough that nearfield feels to me like you really need your head in a clamp for proper sound.
Would rather use headphones myself.
Well also in my subjective experienxe, you get better “soundstage” or instrument separation with some more distance.
Reactions: EJ3
- higher clarity
That would be news to me, many people on ASR invest very heavily into their near field rigs.
Nearfield gets plenty of love here:
Why do you think this premise is true?
Well, audiophile setups typically aren't nearfield. I know that when I think audiophile setup I don't think of nearfield. People tend to use towers or bookshelves on stands, and most are either dedicated listening room, or a living room or HT with a TV. Example of user systems, majority aren't nearfield! Sure, a lot of people use computer speakers, and musicians or sound engineers do use studio monitors, but for some reason it seems like it hasn't become really popular in the audiophile crowd.
It's almost like it's not really taken seriously. When you go to hifi stores, nearfield setups are basically inexistant. You're better off going to musical instruments stores which will have pro gear. Even when you go to hifi trade shows, with 100+ rooms, there's basically zero nearfield setups, which btw would sound so much better than 95%+ of the systems there for a fraction of the price...
Even myself, after more than a decade in the hobby, it was dedicated room, then headphones, then it's like I've just recently waken up that I might as well just give up on a dedicated listening room and just go full nearfield!
It's almost like it's not really taken seriously in the audiophile world. Even when you go to hifi stores, nearfield setups are basically inexistant. You're better off going to musical instruments stores which will have pro gear. Even when you go to hifi trade shows, with 100+ rooms, there's basically zero nearfield setups, which btw would sound so much better than 95%+ of the systems there for a fraction of the price...
I love the ritual of sitting down in front of my "music shrine"... stereo, 7.5ft triangle. But I do a lot of fun listening on my work office rig... both near field and headphones. Since I am forced to sit in front of my computer for work a lot of time, that's a great thing.
Some reasons for near field setup not being more popular:
- Proper near field listening is more or less a solo experience. Many people prefer to have something better suited to group listening experience.
- Some people want to have big tower speakers, which are not suitable for near field listening.
- HiFi equipment manufacturers and sellers typically preach the minimum of 2 m (6.5 ft) triangle sermon, and many customers tend to believe them.
- While the importance of room acoustics has gained wider recognition lately, there are still lots of customers who are more or less oblivious of it.
- A near field setup in a living room is often frowned upon by the family members that are more aesthetically sensitive.
- Some people seem to prefer more reverberant sound.
I expect pablo's experience is a common one: hifi setup at a distance, with a comfortable seat, that can double as a music source for guests, friends, gatherings, etc. + a nearfield setup for desk sitting. Practical and flexible.
As for me, I don't want to encourage myself to spend more time sitting at a desk than I already have to, so I mostly resist urges to make my desk setup more comfortable and appealing.
Reactions: GM3
