Dear fellow forum members,
First of this forum has helped me a lot with choosing my speakers.
Hopefully you can aid me in my DIRAC problems.
I have used DIRAC extensively in the past on my NAD C658, I'm familiar with how everything works.
Hence my suprise to what happened when I applied DIRAC to my new KEF R3 with custom build subwoofer.
Setup:
Speakers: KEF R3 + Push/Pull subwoofer (10").
Amp: NC252MP for the R3 + NC500 mono for the sub.
Source: MiniDSP flex (balanced) with USB attachted to computer for measurment.
Mic: UMIK-1 (with cal file)
Crossover: 60 hz with a 24 db/oct roloff
DIRAC in shown measurements: +2db harman kardan with a slight -1 dB roloff in the higher region (standard starting curtain), full range.
You see what happens to the spl curve and waterfal with and without dirac.
The final images are a waterfal and spl curve when I apply some mild EQ manually (max Q = 3, max gain = 3 dB) and a HK + 4db curve from 200 hz.
Why does DIRAC completely cutoff the suwoofer and lower part of the KEF's?
This did not happen when I used DIRAC on a pair of genelecs 8030c in the same setup.
Thanks for your advice!
Setup:
