Just for the record., your intended term is "Euphonic" distortion. [I guess these people think like guitar players into tube (transformer, mostly) amps, like to add a cup or two of second order harmonic distortion along with the reverb and chorus].Three things come to mind.
1. Better mastering; no loudness wars for vinyl.
2. Euphoric distortion.
3. Psychoacoustics. When I am going to focus on music with intent, I usually pour a drink and put a big wholesome record onto my gorgeous analog system, after taking pride in ownership of the physical medium and spending a moment looking at the artwork in my hand. It sounds way better to my ears than the digital I stream while working.
That too.It's all down to the fact that you can roll a spliff on a record cover.
As far as I understand the majority of reviews of analog gear the term euphoric distortion describes it perfectly.Just for the record., your intended term is "Euphonic" distortion.
Select psychotropics administered under ideal circumstances induce "Euphoric" distortion. So far, this has been the single greatest and potentially most cost effective upgrade of sound quality.
Winky face means it's a joke. Welcome to the 21st century. If you read the whole thread, you'd see I am agreement that digital has better sound objectively.I have no interest in anyone else's "conditions". They can't negate more than 45 years of lived experience. I've put in thousands and thousands of dollars into analog equipment (tables, tonearms, cartridges, cleaning machines, fluids, setup tools, phono preamps, etc) and literally many thousands of hours into table setup, collecting, and cleaning records. I will not waste more time on such a manifestly inferior medium.
I own thousands of records and 4 turntables (ranging from modified Japanese direct drive to air bearing with a 70 lb platter), and can tell you for a fact it has nothing to do with 1s and 0s. If I make a digital recording of any of my records with any of my turntables you will not be able to distinguish the turntable reproduction from the digital recording in a volume matched blind test.Can't do that with 1s and 0s.
Best vinyl record player is laser... no needle contact. This puts some in a quandary… is it still vinyl?
https://www.elpj.com/
JSmith
I have no interest in anyone else's "conditions". They can't negate more than 45 years of lived experience. I've put in thousands and thousands of dollars into analog equipment (tables, tonearms, cartridges, cleaning machines, fluids, setup tools, phono preamps, etc) and literally many thousands of hours into table setup, collecting, and cleaning records...
The coolest thing about these is that they're all-analog.Best vinyl record player is laser... no needle contact. This puts some in a quandary… is it still vinyl?
JSmith
I thought speakers are analogue. I guess a good match until humans are digitized.The coolest thing about these is that they're all-analog.
My comment applies to everyone, regardless of which side of the debate you find yourself on: your years of lived experience doesn't matter to anyone but you.
Not picking on this poster specifically, but using it to highlight that people can't even accurately compare things that happen 45 seconds apart, let alone have a proper recollection of things that happened 45 years ago.
When comparing one thing VS another, properly controlled blind A/B testing matters, not your lived experience.
That said, In the 80's, I had the most excellent sounding boombox for all my cassettes (fond memories from after-school hangouts).
No, although that's true of course, but I'm saying you can literally feel the music in the record grooves. And understand it. You can't do that with 1/0.Are you saying that the "magic" disappears for you if you digitize the output of your turntable and play that?
Sure.It does.
