MattHooper
- Joined
- Jan 27, 2019
- Messages
- 10,643
- Likes
- 18,668
Is there a reason the MBLs couldn’t be run active?
I don't know.
My point though was about the existing difference in choice with passives vs actives.
Omnis are good for non critical listening and for parties.^^^ This post from the first page also seems like a good point about the limited practicality of active speakers.
I myself really dislike any added power cords in my listening room. Much more hassle (and harder to hide) than speaker cables. (One of the reasons I got rid
of my subs, the annoying requirements of finding a good spot for them but also near enough a power outlet, etc).
Is it possible that generally speaking a powered design will eek out some performance over a passive version of the same speaker? Sure. But in terms of the actual speaker landscape of existing choices, I try to keep the actual sonic gains in some perspective. Whether it's demoing active vs passive speakers at the shops, or hearing active speakers at shows vs all the other designs in other rooms, I've had no come-to-jesus experience hearing an active and tended to be more impressed by some of the passive speakers. I mean, for me, gimme an MBL 101 over a Kii 3 any day of the week. I know others would prefer otherwise. But...choice is why it's good passive speakers still exist.
Brutal analytical sound is the ultimate pleasureLOL. We've been here before.
Actives are ok for studio work, but don't try using them for pleasure ;-)
I have. Cerwin Vegas both home and pro, big JBLs, Infinity Kappa Series, Celestion. I liked them all. All colored in my opinion.I have never found much pleasure in colouration, many do of course.
Which speakers are you using NIN?
Best in what particular way? Noise? THD? Dealing with corner case speaker loads while simultaneously dealing with corner cases in high power ultrasonics? Power per dollar? Efficiency?
I only have so much grasp of the current speaker landscape, but I looked up your two examples and it just got me wondering about how much of this is cultural vs technical. As someone who has built custom crossovers and is currently in the process of designing an active and passive version of a speaker for a particular purpose, there doesn’t seem to be a technical reason why one would be better than the other.I don't know.
Class D is as good as is necessary and a little more. The latest gen big amps have improved in construction and low impedance drive. It's good enough for prime time... I think anyway. Keep in mind mono block class D amps are putting out heaps of power. So the upper price range has options that are not crazy expensive and will satisfy most all speakers other than the worst of the worst maybe.
www.audiosciencereview.com
Fair enough. Since really good class Ds distortion is inaudible to me even at those frequencies (to be fair I can only hear up to 16 kHZ) it is a technical distinction without practical meaning.Lower THD at 10khz and 20khz
Not my words Matt, Bang&Olufsens from the Beolab 90 white paper.
I agree with them though.
I'm not into a specs and tests debate. 100 W/ch and 200 W/ch FFTs look nice. Class A, AB and D have their places. Class D is the modern choice. More efficient, cooler running, high power and cost all add up to a great value. Otherwise buy some nasty load speakers and big fat class A/AB amp and run it hot and heavy.Well, Class D can be really good but afaik there is no class D that have as low THD at 10kHz and 20kHz as the best AB.
2nd harmonic of 10kHz is 20kHz, 2nd harmonic of 20kHz is 40kHz. HD at these frequencies is not audible.Lower THD at 10khz and 20khz.
You get called out for disrespecting your audience (by refusing to share your list of disadvantages of active speakers because you say readers won’t behave well enough) and your response is to double down by this time making it personal? I am detecting a trend.If you ask that way, the answer is no. Don't ask again and don't put words in my mouth. You are exactly what I was worried about.
