Why do most Stereo Preamps not have HDMI input for Audio?
rimmi2002
Hi,
I have seen / read many audiophiles prefer using a 2.1 / 2.2 system with high-end speakers without a center channel for music and HT use. I was looking into that and saw that most stereo preamps do not take HDMI input (like an AVR, which takes HDMI inputs from attached devices like Apple TV, and processes the video separately and audio separately for amp or preouts).
So I wanted to ask how people do their setups for HT use with such systems? Are they using ARC via Toslink from their TV or projector?
I just thought HDMI has much more bandwidth than Toslink cables, so for movies having an HDMI input for audio would be nice (even though a stereo setup will not play Atmos/DTS-MA or any 5.1 soundtrack as 5.1, but I figured at least that way the preamp gets the best audio quality to process for movies). Or does that not matter?
Probably licensing fees are a factor, and, many manufacturers might think, customers wanting HDMI will also want multichannel, so they will buy either an "Atmos enabled" soundbar setup, or a "real" HT. Not wrong, really.
That said, HDMI at least in every DAC/preamp/HPA combo would be nice to have IMHO. Even if I have no use for it today, I might have it later.
The bandwidth on HDMI is to capture uncompressed video. The audio files - compressed or uncompressed - are tiny in comparison.
I really doubt you'd hear a difference in audio between HDMI and optical. But hey, give it a try and let us know.
It's not for sound quality (which I never stated), but for convenience, simply. The original HDMI concept was "one cable for all".
And, if implemented consequently, it can be (HDMI passthrough, Ethernet etc.), for audio and video.
@respice finem - of course you mentioned sound quality:
"..but I figured at least that way the preamp gets the best audio quality to process for movies..."
Not sure where you were going with that one.
Wrong glasses? I'm not @rimmi2002
Ego te absolvo :)
Hi,
As long as there's a pass through output for video. I'd be perfectly happy with a 2.1 setup with my TV.
AI Overview
Yes, the McIntosh C53 has an audio-only HDMI Audio Return Channel (ARC) input, which allows you to connect it to a compatible TV to send your TV's audio to the C53 for playback through your home stereo system. However, this is not a standard HDMI input for passing video or non-TV audio sources; it's specifically for audio from a TV's ARC output.
I thought my Mcintosh C53 had HDMI. I just didn't want to hunt up the ops manual or get behind the thing. That C53 does everything, including reading my mind. Considering I still have my C20 from over 50 years ago. I'd be using that C20 a lot more if it had a remote, though. :-) Wonderful how it works and sounds after it was freshened up by Samra.
Regards
Thanks everyone for your input. So from what I hear passing audio through ARC via TOSLink will be similar in audio quality vs HDMI source for a 2.1 system.
My sources are ~20 ft away from my projector. If I do end up going this route, then a better way to go would be to just buy a HDMI switch to substitute for my AVR's ability connect multiple devices.
Setup would be:
1) All sources go to HDMI switch inputs
2) HDMI OUT goes to projector
3) Toslink Connector from HDMI switch goes to Preamp
Does that sound right?
If you have an AVR, why not plug all devices into it?
If your concern is cable length (for the projector), you may buy a "HDMI optical" cable.
These go up to 100 m.
If you really need to split the digital audio from an HDMI input and make it available as SPDIF, you can get something like this for about $20.
In my system I also need to convert HDMI video to VGA or RGB component for my 20 year old plasma screen, so I have a single box that does this, as well as splitting the audio and making it available as SPDIF.
Setup would be:
I've got a Sony Blu-Ray player—BDP-BX57—and a few Blu-Ray audio discs. My 2.1 audio system includes a Topping E30 DAC. It doesn't have an HDMI input, necessary to play back the Blu-Ray audio discs. So, I got an adaptor recommended here at ASR. It appears to downsample hi-rez recordings, but sounds fine:
That is what I have setup now with a AVR (onkyo NR7100). If I go the route of a stereo preamp / amplifier for a 2.1 setup, I was wondering how to make it work with all my devices similar to AVR, since most of these stereo preamps don't have HDMI in's / outs.
From what I hear (I will test it out myself before spending on preamp/amp combo) the AVR DAC are not that as good as good preamps DACs for stereo setup.
The DACs in AVRs are probably good enough, considering the limits of human hearing. Otherwise, you have the option of getting an outboard DAC with an HDMI input or do what I did, a good performing but cheap DAC with a HDMI adaptor. If all your sources are digital, you can bypass the preamp altogether.
Ah, OK...
Hi,
I have a two-channel setup and have a similar issue. A Sony STR DA3400ES is acting as a pre/pro feeding my Anthem MCA225G2 power amp. Streaming comes from a Chromecast Audio via optical and disc/USB sourced audio comes over HDMI from a Sony UBP X800M2.
The player has only HDMI and S/PDIF coax outs, no analog. DVD-Audio's performance over coax is limited to non copy-protected material at 20bit/192KHz. Supposedly 24bit is supported by the IEC 60958-3 standard but I've had no luck with that. Likewise, the SACD's DSD stream is not going over unencrypted S/PDIF links.
So that leaves HDMI and here is part of the problem. Manufacturers simply have no interest in including a fully licensed HDMI chipset into two-channel equipment.
My intent was to upgrade to a stereo pre/pro with HDMI input and retask my space heater... I mean AVR. But it looks like that is not happening with my current setup.
Did not read past the OP.
Because HDMI sucks as an audiophile interface.
There is no standard for audio-only over HDMI, the pinouts vary by manufacturer.
Best is to use an "audio extractor" to feed your audio gear, that outputs to a selection of digital formats, or at least the one you prefer. TOSlink and Coax S/PDIF are of course bog standard, which is A Good Thing™
If AES3 is an option, it's a good one. Avoid USB unless you have a strong reason.
ADAT is great for cheap MCH to DSP, so long as you aren't bamboozled by resolution issues.
Beware length vs signal integrity issues
