Mark185
- Joined
- Jan 30, 2025
- Messages
- 107
- Likes
- 110
I have noticed with the exception of Amir, no one seems to publish a full set of measurements that show distortion vs power and frequency. I recently purchased a used ARC Audio 1000.6 amp rated at 175 watts per channel. This is considered a very high end Class D amp and I think it does measure well at 5 watts. I understand why marketing concerns would keep manufacturers from showing the whole truth but it is still somewhat disappointing to see what I am measuring.
I have a Quant Asylum analyzer and have been experimenting with measurements on the ARC amp and some others I own. I will caveat this by saying that I am not using a high pass filter like Amir uses with Audio Precision equipment to filter out the switching frequency of Class D amps. I am building one from plans I found on the internet but it is not finished. I also have problems with radiated power line noise and an FM transmitter at a nearby fire station. I use good shielded cables and the differential inputs on the QA403 but still have some noise getting through so my measurements are probably a bit lower than these amps are capable of. The value to me is that my test conditions are the same for all so I can still compare. Having said all this, here are some plots that tell a story.
At ~5600 Hz and 106 watts the measurements are quite different:
Going down to 125 Hz at 5 watts, this is the picture and its not bad.
Going to higher power at 125 Hz and here is the result:
