Why do I always encounter phase problems after Dirac measurement?
bark
Hello everyone!
I purchased the Dirac+BC+ART bundle and miniDSP UMIK-1 for calibrating my 2.1 system.
However, I notice that every calibration result exhibits phase issues at certain frequencies. After each remeasurement, the problematic frequencies change. Sometimes it is most noticeable at 170 Hz, while at other times this frequency shows no issues at all - this is just an example, as many frequencies are clearly out of phase.
To identify the reason, I have tried the following approaches:
  1. Calibrating only the 2.0 system without the subwoofer
  2. Disabling ART and using only the basic Dirac RC or RC+BC modes
  3. Fixed-position calibration and handheld calibration
  4. Auxiliary measurement points over a wide range or a narrow range​
  5. Use single point measurement for RC or 3 points measurement for ART​
  6. I also tried checking the phase after Dirac processing using sine waves in a DAW. I can clearly see that phase correlation is poor (even negative) at some frequencies. Sometimes these regions sound fine to the ear — Dirac does align certain frequencies that previously suffered from cancellation. However, other frequencies that originally sounded okay end up being cancelled as a result.​
Additionally, my room is asymmetric, and I wonder if this could be one of the causes of the issue. For reference, I have bass traps in the front-right and rear-right corners of my listening position (I cannot place traps on the left side of the room). Absorbers are also installed at the first reflection points on both sides and the ceiling.
I’m not sure how to resolve this problem. Does anyone have any ideas?
Hello everyone!
I had timing /phase/ imaging problems with ART with a PC based 2.4 system (2 co-located and 2 support subs) and I found I had to move the support subs closer to the LP, about the same distance as the mains / colocated subs are from the LP. This solved the timing issues for me but the subs ended up in an inconvenient location. Hope this helps.
Here are a couple of reasons:
1. It's a measurement artefact. Every time you move your microphone, the pattern of reflections change. Reflections interfere with the direct sound and will cause the phase to shift. This is more likely as wavelengths get shorter. To avoid this, you must either choose proper frequency dependent windowing, OR you leave your microphone in place (DO NOT TOUCH IT) for the before-after measurement.
There are in fact more reasons for the phase to change. For example, if REW places t=0 wrongly (as might happen if you fail to use a proper timing reference), it will alter the phase curve.
2. It's caused by Dirac. All corrections done by Dirac are minimum-phase (sometimes mixed phase). This means that any equalisation will also alter the phase. Ideally, you only want to correct minimum-phase regions in your frequency response. This will also change the phase, but it will move it towards the more "correct" response. But if you are ham fisted with your correction, you could easily make things worse.
Don't worry about phase. Worry about the frequency response. ONLY worry about phase if you have a solid understanding of what it is and what causes it to change.
Out of phase with respect to what reference? Subs vs. Mains? Left Vs. Right? etc
Left Vs. Right. I can clearly notice cancellation at certain frequencies when I manually sweep a sine wave or play pink or white noise, even when I'm not using subwoofer.
Thanks for your detailed reply! I’m indeed concerned that complex room reflections and ambient noise might be the culprit. My setup is in an asymmetric bedroom where ambient noise (PC, air conditioner, and even bird call...) cannot be controlled. Minor variations across measurement points could potentially trigger sharp phase shifts.
As for my concerns regarding phase, I started paying close attention to it precisely because I hear obvious cancellation. Certain frequencies sound unnaturally broad, which stands out especially during sine sweeps or when playing white/pink noise.:facepalm:
If you hear obvious cancellation, you first need to measure the cancellation. First thing you need to see is a dip in the frequency response over a spatially averaged area - so you either take a MMM or take sweeps from multiple positions then vector average them. In turn, dips will be due to interaction between two or more speakers, or sound interacting with its own reflection. You can exclude the former by taking a measurement of each speaker in turn (WITH a timing reference!) and then vector summing them. If the dip is absent in the individual measurement but only appears when summed, that's the diagnosis.
Please read the REW book in my signature. You want Book 2. There is a length explanation on phase, and there is also a procedure for diagnosing dips in the frequency response.
The most likely cause is that your room treatment is feeding Dirac bad or nonsensical measurements. The correct approach is to use correction software first, then treat the room to improve the DRC results or fix issues that DRC could not. Simply blocking the 24 kHz impulse peak can corrupt the relative timing/distance calculations, especially if the measurement process is too simplistic.
A second likely cause is random clock drift in the PC you’re using to measure. This is especially relevant for some Windows 11 devices with hidden audio settings (which let the laptop listen covertly) and certain chipsets: they cannot sync the USB microphone clock with the audio output clock, and no DSP software can work correctly with those results.
THANKS SO MUCH! I'll read your book and try to measure it again
Is there any software that can capture clock drift between the USB microphone clock and the audio clock? If not, can this issue only be avoided by using a Mac computer, or by using a calibration mic that connects via an audio interface (such as Earthworks or Dayton)?
You can measure your a speaker with REW using the same USB mic set up. Ensure you select "Use acoustic timing reference" and take one short (i.e. 64k and one long i.e. 1M length sweep and check the "Info" window for calculated clock drifts in ppm. You can even tick "adjust clock with acoustic reference" option under Preferences/Analysis tab if you want REW to compensate for clock drifts (something Dirac unfortunately doesn't do!). Even small drift amounts around 25ppm can cause significant phase shifts in the measurements.
I can also suggest using Latencymon, a free Windows diagnostic tool that measures kernel timer latencies, DPC (Deferred Procedure Call) and ISR (Interrupt Service Routine) execution times, and hard page faults to check if a system can handle real-time audio and other low-latency tasks. It's no cure for clock drifts though.
If it helps what I frequently see in problematic laptops with GSonic are some sort of hidden power saving (balanced plan, usb selective suspend, etc).
Edit: and avoid sub par usb hubs/extension cables!
DIRAC is specifically designed and optimised to use USB MICs, it has problems with MICs with interfaces not with USB MICs
had the same problems with DIRAC+ miniDSP- about a year ago i stooped using it with the thought i did something wrong.
Bought Sonarworks instead- a bit better results- not satisfying.
-at least both are not immune to dumb user.
took last try with IK-multimedia Sub (ARC software) one cycle of measurements..... and it works perfectly fine!!+ it is fun to play with the integrated simulations.
ps.:
this accords to my desktop setup: ADAM D3V+Sub.
Dirac did really ****** things to my main setup: ADAM S3V
funny things happen across the pond: it is not allowed to talk about biological waste but there is no problem with tasteless "humor" postings on the cost of disabled people.
-must be God*s own country.....
