notsodeadlizard
- Joined
- Feb 18, 2023
- Messages
- 403
- Likes
- 379
Perhaps for the same reason accordion players don't use chainsaws.
It just isn't necessary.
[ominous dramatic music]if you are rocking a newer Class D like Hypex NC or Purifi, adding some second order harmonics can give you that perfect sweetness on top that might be missing, and bring some musicality back into the amp.
Haha.. Not that they arent already musical, but oh man.. I wish you could have seen the look on my girl's face when I enabled Saturn 2 with clean tubes preset, and barely turned the drive up, while listening to solange - cranes in the sky. (gotta keep her entertained)[ominous dramatic music]
What's a 'VST'? When using an acronym that not everyone may be familiar with, please spell it out once in the beginning, and then use it as needed later.Why "audiophiles" don't use VSTs? Concept is pretty clear - you would get objectively saying the most precise amp, speaker - entire audio rig - and then colorize signal digitally at source (well, you could route analog signal to the actual analog rig, but plugins mimic analog rigs so well already), add up some distortion (Ozone Pro Exciter, Fabfilter Saturn etc), EQ (Pro-Q etc).
I've been observing the audiophile community for a pretty long time now and I've noticed all conversations come down to one thing:
People just don't like the mix, it's literally that simple, either song is actually poorly mixed or people just don't enjoy the tonality that audio engineer offered them.
Also why don't we have DSP's with support for VSTs? (I don't know any, if you know one, let me know)
Maybe money is the issue as always? Amp can be sold for 5k USD, typical plugin goes for <500 USD (and that's most often the price of entire bundle!), so it might not be worth it for audiophile companies to change the mindset behind the "audio quality"
Or maybe, I don't like to put it this way, but maybe audiophiles are just too dumb and they think measured gear distortion is different from the same but digitally applied one? (Same thing goes for EQs etc)
An """audiophile""" using a VST to improve the sound doesn't happen for several reasons:
Bottom line, I think the type of audiophiles we're talking about aren't really interested in chasing down genuinely better sound. If they were, they'd behave very differently, VSTs or no. They enjoy the process of swapping out gear and telling themselves how it sounds. IMO this isn't really a problem except when they start telling everyone how ignorant they are for not hearing (read: imagining) what they do.
- Most VST interfaces assume some familiarity with how audio actually works, which is a problem for them (not ONLY being snarky here)
- VSTs are all digital, which for many """audiophiles""" means they are inherently incapable of improving the sound
- The idea that software can improve the sound in a similar way to physical gear conflicts with their entire "career" of chasing small distortions through large price tags
- The nature of a VST is to actively participate in changing the sound by making concrete, specific choices about what you want to hear, by tweaking knobs or changing settings. """Audiophiles""" like to imagine that changes to sound are in some way unknowable or unmeasurable, inherent to some alchemical aspect of the gear. This is exactly the opposite of how VSTs work.
- VSTs are too cheap for them to imagine they actually sound good. (mentioned by others.)
- Using a VST means being pinned down on exactly what it is you like about audio. Is it harmonic distortion? A little extra compression or boost in the lows? mid-side processing? If you just buy gear randomly you can keep talking in subjective terms like "musicality" and "flow". If you use a VST you have to finally admit you just prefer more H2 and H3 distortion, it takes the mystery out of your own preferences.
I am saying this because we all have different definition of what is better or worse. To some, better means its as close to the recording as possible. If there are flaws in the recording, the gear should reproduce it faithfully.
I'd rather seek new experiences by listening to new music, instead of monkeying about with sound plugins. I think you get way better bang for your time.In other words, as an audiophile seeking new experiences, i would say it may hurt you more having NOT tried VSTs, than to have tried them and decided they werent for you.
I think you should do that if it makes you happy. It's no longer high-fidelity, but maybe you don't care.Why do you want to get as close to the recording as possible? Don't you want to get as close to the performance as possible?
That's my point, I don't necessarily believe that mastering engineers know what's best for you. I have enough bad recordings in my collection to know that.
As I said, I have absolutely no problem with that. You realize that you're striking off on your own to fix perceived problems in the recordings.With the flick of a switch I can turn all the VST's and all my processing off and it will be "high-fidelity", but then it sounds a bit too dry for my taste. I get that my approach is not for everyone, but for me VST's are a way to tune my system even more for not much money, or even for free. What's there not to like about "free"![]()
"but they do alter the sound" - Yeah sure, but it's imprecise as hell! "Reverb", "Treble", "Bass" are very general terms.While software based VST is something very new. Hardware solutions that has similar effects do exist. Some amps have built-iin controls like treble or base, reverb, etc... treble/bass controls exist on pretty much every AVR in the market as well. No doubt they aren't as versatile compared to VST, but they do alter the sound.
I don't think there's anything low-fidelity in eqing the sound. Do you also call audio engineer's work low fidelity? He uses eqs too, MULTIPLE eqs. Do you call mastering engineer's work low fidelity because he increased harmonics in transients? How max 3db eq (that's the upper limit in my understanding of eq'ing the sound to your flavour) relates to "losing fidelity"? While mixing engineer nails the overall balance of sounds in music, mastering engineer gets the tonality just right for his ears, why wouldn't you want to become your own mastering engineer just to get that 1db of presence in voice louder, or remove just a little bit of boxiness from master? I'm using subjective terms here intentionally (even tho I'm hard objectivist), I think people's perception on sound can vary, depending on genres they listen to and there shouldn't be anything low-fidelity to applying little eq.I think you should do that if it makes you happy. It's no longer high-fidelity, but maybe you don't care.
Once you purposely modify the sound from the original recording, you deviate from fidelity in any normal sense. This really has nothing to do with the creation process. People do any number of things as they record music that are completely inappropriate for reproduction.I don't think there's anything low-fidelity in eqing the sound. Do you also call audio engineer's work low fidelity? He uses eqs too, MULTIPLE eqs. Do you call mastering engineer's work low fidelity because he increased harmonics in transients? How max 3db eq (that's the upper limit in my understanding of eq'ing the sound to your flavour) relates to "losing fidelity"? While mixing engineer nails the overall balance of sounds in music, mastering engineer gets the tonality just right for his ears, why wouldn't you want to become your own mastering engineer just to get that 1db of presence in voice louder, or remove just a little bit of boxiness from master? I'm using subjective terms here intentionally (even tho I'm hard objectivist), I think people's perception on sound can vary, depending on genres they listen to and there shouldn't be anything low-fidelity to applying little eq.
Please notice I didn't mention colorized speakers anywhere in this post.
And as I said, I'm not loosing sleep. Modify to your heart's content!So? I've no problem using tone controls to adjust to my taste or compensate for mastering/recording. I use dynamic loudness as well, and for me that is a needed feature when listening at lower volumes.
NAILED IT.An """audiophile""" using a VST to improve the sound doesn't happen for several reasons:
