localhost128
- Joined
- Jul 23, 2020
- Messages
- 55
- Likes
- 49
have you clicked the link I posted below that post you are responding?
we hear the room below 800-1000Hz-ish.
you can do a simple test with a tone generator. run a sine wave at let's say 100Hz and move in you room. how come there will be HUGE variations in SPL? because you are not hearing direct sound. you can actualy find frequencies where the SPL directly in front of the sepaker will be quite low, and huge elsewhere in the room. play around with a tone generator since it will show you so much about your room in general
i think you're confused and/or don't quite understand just what the term critical-distance (Dc) entrails/implies.
what you're describing above for simple modal resonances (eg, 100hz) is their inherent localized behavior. localized as in the pressure wave has a vector/direction component (nodes/antinodes for an axial mode, for example) - completely contradictory to the acoustical definition of reverberant sound-field (random/diffuse-incidence; ie, no direction). to even infer 100hz in this discussion is completely erroneous and not valid in the context of critical-distance (Dc).
the link you provided is a calculator, not a measurement or direct, objectionable data that confirms what the user said above that in a normal room, Dc somehow exists at a mere 1meter from the loudspeaker/source - and thus implying at distances beyond (2,3,4meter), the indirect sound-field would completely dominate that of the direct signal. this just simply does not happen and hence why objective data to support the claim was requested.
and added as to what the other user claiming (without any data to support) that "Otherwise statistical properties set in in just about every room at a few hundred hertz above transition frequencies" (ie, 450hz+).
we do not apply absorption statistically in Small Rooms (normal, residential-sized rooms) a few hundred hz above transition frequency (~450hz) because no statistical sound field exists. it is all localized behavior with direction (ie, indirect specular reflections that can all be measured/resolved/and traced back to their incident boundary). ie, we place absorption or other treatment at reflection points to surgically address specific indirect signals - not randomly applying absorption within the room to bring down the Reverberation Time (implying homogeneous sound-field equal throughout the room). statistical equations are not applied in small rooms because the physical characteristics of the sound-field don't exist. they are Large Room equations, not meant/valid for use in Small Rooms. garbage in = garbage out, as i was taught in university.
what i'm starting to question now from this conversation is whether anyone commenting against the basic understandings/foundations of acoustics has even stepped foot and done any analysis in concert halls, auditoriums, churches, etc and other Large Acoustical Spaces that exhibit a reverberant sound field and critical-distance (Dc) that is easily perceived.
but i will gladly be open to reconsider if objective measurements can be provided that show a critical-distance (Dc) at 1meter from loudspeaker, and that at 450hz and about in "just about every room" such is valid/relevant. even from a subjective-perception perspective, it should be easy: listen to your loudspeaker or television set or radio or any other noise-generating device in a "normal" residential/living room and determine if at 1meter (~3ft) the indirect sound-field is equal in gain to the direct signal - and when walking 2,3,4 meters and with your back against the rear wall of the room whether the indirect sound-field completely dominates in magnitude over the direct signal to the point where perception of the direct signal is becoming lost.
