fpitas
Many full range afficianados end up with some hf notch filtering etc.I will find out….
I already have my 8340 as references - Im not gonna do a notch filter in the summers DIY , but real music gonna be my reference ( my wife is a flutist )Many full range afficianados end up with some hf notch filtering etc.
Well, good luck. My ears find massive treble peaks like that to be painful. YMMV...I already have my 8340 as references - Im not gonna do a notch filter in the summers DIY , but real music gonna be my reference ( my wife is a flutist )
I agree but are we not just swapping one set of compromises for another? I would take a two way any day if it were that or the single driver since the foibles of the single driver bother me more. I accept there are people who would go the other way on that call though.Yes , 2 ways are troubled because the crossover is in a sensitive area and the size difference between the bass and the tweeter are to big to be inaudible - This is easier to make good with a dsp 3-way speaker.
But the point is , a good fullrange driver dont have any crossover point in any sensitive area for the brain/ears.
This might be the one of two reasons it might have some qualitys that 2-way speaker lacks. The other advantage with a full range driver is that all the sound are coming from one spot, very audible If listening nearfield.
If you have candidates, send me one and I will test. I have only tested on with a 4 inch driver that performed extremely poor: https://www.audiosciencereview.com/...research-lgk-2-0-speaker-review-a-joke.34783/
Heretic!I don't dislike 'em at all.
As I have likely mentioned before, that "augmented fullrange" approach can be a good oneI've seen several serious DIY efforts that used full range drivers as midranges. In that service, they did get a crossover.
i have actually studied sound engineering at university level and back then I remember the lecturer said such a driver does not exist that can do 20-20.
that was over 20yrs ago but I doubt the technology has changed... be willing to see if such a driver exists, even if it does it fairly poorly
i assume no crossover would be needed?
I love the speaker wire routing.SoundLab makes large electrostatic loudspeakers that are uniformly driven across their entire membrane which can do 20 Hz to 20 kHz. While this is not what most people have in mind when they say "single full-range driver", arguably it IS a "single full-range driver". What looks like individual "cells" in the photo below is the frame; the diaphragm is one large sheet of very very thin Mylar (the gradation in the vertical heights of the "cells" arises from an innovative bass-extension technique):
I have been a SoundLab dealer for over 20 years, and they date back to about 1978 as I recall. Ime they really do the full spectrum with exceptional radiation pattern uniformity. It was my analysis of their radiation pattern twenty-four years ago that led me to buy my first pair unseen and unheard.
SoundLabs DO have a crossover but not for the usual reason. Their reason is, to keep the impedance curve manageable. The impedance curve of an electrostatic loudspeaker is generally capacitive (rather than inductive); in other words, the impedance decreases with increasing frequency. SoundLabs have a low-frequency transformer and a high frequency transformer, with a crossover in the 400 Hz ballpark as I recall, and the resulting two-hump impedance curve keeps the impedance within a range that real-world amplifiers can drive.
I love the speaker wire routing.It all looks very real and practical. Those tube amps look formidable.
I would love to know the tube amp manufacturer it looks like a powerful layout.I don't recall where that photo is from. Probably from an audio show. I would pulled 'em further out into the room, toed 'em in a bit more, and NOT used absorptive panels behind them.
But yeah the speaker wire routing neatly avoids the issue of "cable lifters" altogether!
www.lii-audio.com
The 100 dB scale on the frequency repose?The DIY builders seem to love these. I'm tempted, what am I missing?
One Pair | Recommended 15" Full Range Speaker Driver | Fast High and Scaled Sound | F-15 - Lii Song (Lii Audio), unique speaker, amplfier, quality and cost-saving parts for HiFi DIY
Technical Data: 1. PMSE-Free 1.35 Ohms 2. Fs 49.6 Hz 3. Re 6.56 Ohms(dc) 4. Qes 63.78 Ohms 5. Qms 7.45 6. Qes 0.78 7. Qts 0.71 8. L1 0.11 mH 9. L2 0.47 mH 10.R2 3.57 Ohms 11.RMSE-load 0.85 Ohms 13.Vas(sd) 178.5 liters 14.Mms 13.70 grams 15.Cms 1473 uM/Newton 16.Bl 5.92 Tesla-M 17.Splref(sd)...www.lii-audio.com
I had a feelingI edited my post while you were posting. Those are Atma-Sphere MA-1's.
The problem with a single driver is physics. You need a large piston for good bass response but a small one for good high frequency response. It’s not possible to have a ten octave range and have acceptable values throughout the range.I am aware that these have a few issues, from IMD, to limited SPL capability, and beaming at higher frequencies, but are they so poor at these aspects that single driver sets are basically a pointless design to consider? Or is there something else about them that makes them such an unattractive option measurement wise?
