Who is using a Preamp?
I have always loved integrated amps.
Like Einstein famously said, "Everything should be made as simple as possible, but not simpler".
To me that means a capable and feature rich "Preamp DAC", because the built-in apps and streaming API connections will always get obsoleted, and should simply be highly replaceable devices. I like as much functional integration as possible, minimalism is my mantra. But too much integration also leads to accelerated obsolescence these days.
My Topping Pre90 has been sounding like nothing in my setup for almost four years now, great piece.
I use a Sony TA-E1000ESD from 1989.
A 13 year old Emotiva is 'long in the tooth'? lol.
ME!
I use preamps:
I copied this about them off the internet (and I agree [also there is much more that Tom Holman has done, even fairly recently, it is worth looking up his accomplishments. I'd be surprised if less than 50% of people that listen to audio in any form {that would include sound at the movies and from computers}] have never heard audio coming from something that came from some company that he was involved in):
Apt Holman Preamplifier
(1977-1983)
© 2015 KenRockwell.com. All rights reserved.
Perspective
The Apt Corporation's Holman Preamplifier is the most well thought-out stereo preamplifier ever designed.
It was designed at the very height of recorded music's reign as the dominant form of home entertainment (home video was still years away), and was designed by none other than the brilliant Tom Holman, the inventor of 5.1 audio and the inventor of THX motion picture sound.
More important than its stellar laboratory performance is the fact that this preamplifier is designed to do exactly what's needed to make music, and a music reproduction system, sound great. This preamplifier even has a patented variable stereo expansion circuit, a foreshadowing of Tom Holman's later exploits into multichannel sound.
It uses many ingenious and patented circuits. For instance, in addition to the stereo control, a brilliant volume control system actually varies the amplifier's gain for the best noise and distortion performance, instead of merely attenuating a larger gain as do other amplifiers. It allows us to control the level over a huge range with ease, and always keeps the channels perfectly balanced.
The unique tone controls adjust more precisely than ordinary controls. They are individually calibrated for flat response at their detents.
The Holman preamp is so well thought out that its precise bandlimiting not only prevents distortion in other components, it even worries about the other signals coming into the unit that aren't selected! Its internal wiring is shielded electrostatically with alternate grounded conductors, and the selector wafer switches use several decks and grounds to keep everything separated and without crosstalk. Unselected inputs are properly terminated, not left hanging as they are in most other preamps.
What goes on inside this preamp goes far beyond exotic preamps today, and even more importantly, what makes the Apt Holman Preamp sound so great is that it's designed to perfect the interfaces to and from all the other parts of a system. In other words, rapt attention has been paid in its design to ensure that signals coming to and from this preamp are well conditioned and matched to ensure sonic perfection from the entire system in the real world, not just on a test bench.
The name "Apt" comes from its definition as "an appropriate and intelligent solution to the task at hand." Newer preamplifiers today are mostly 25-pound billet aluminum cases filled with fluff: ordinary analog circuits controlled digitally with showy vacuum fluorescent displays, but missing many of the important control features and superior audio performance of the Holman Preamplifier. Instead of chasing idiotic things that consumers think are important but aren't, like what kind of wire's inside, the Apt Holman Preamplifier concentrates on what's far more important, like where those wires are connected and the analog circuitry around them.
Sound
The Apt Holman Preamplifier sounds great because it's ultra-quiet and the channels stay balanced even at the lowest volume control settings. It's extra quiet because its special gain control circuitry means that it rarely needs to apply any gain at all; it's usually working only as a buffer as opposed to most preamplifiers, which always need to be operating at significant gain, regardless of the volume control setting.
Its outputs are always non-inverting, meaning that polarity is preserved.
As you'll see at measurements, this sample bought over eBay still works great 30 years later, and it was sold as "untested, as-is."
The best part about its sound is the lack thereof: it's so quiet, it's the first preamp that let me hear the iPod touch's audio amp shut-down automatically after several seconds of paused operation!
I can't hear the internal transformer hum or buzz unless I hold my ear closer than a few inches to the preamplifier.
The tone controls are just right for delicate optimization.
For serious headphone listening, use electrostatic headphones like a Stax headphone and driver system fed from the regular preamp outputs, but if dynamic headphones like the Ultrasone Edition 8 or Sennheiser HD 800 are good enough for you, the Holman Preamplifier has a separate headphone amplifier capable of enough output to deafen a drummer.
Mechanical and Electrical
The case is heavy-gauge sheet metal, with pointy front-panel corners and four 3M stick-on 3/4" rubber feet. The knobs are solid aluminum with engraved indices with one hex set-screw each. The passively-lit pushbuttons are plastic and I wouldn't trust them, except that they're the same kind as I've seen on professional studio equipment of the same vintage, and as I've used in my own designs.
The only light is the bright red power LED; the other indicators are passive.
It's got a 10-foot power cord, five rear-panel outlets rated for a kilowatt, and a double hand-signed schematic diagram on the bottom. Holman thought of everything.
(Back to me: having outlets on the back of the APT/Holman prevents one from needing one of these):
My first standalone preamp was a Dyna PAS 3. I've had others since then and have continuously had a preamp in my stereo. My current preamp is a Schiit Saga 2. It replaced an older preamp because I decided to finally get something with a remote control.
I have two good stereo preamps, a Mark Levinson No. 38 and a Sonic Frontiers SFL-1. Lately, I have been using small DACs like the Emotiva DC-1, SMSL RAW-MDA1, and SMSL DO200 Pro, and I have been using their internal volume control to control the system volume. Some people have said this is sub-optimal but I have had perfectly acceptable results doing this. I have had a wide variety of amps, from Hafler, Job (Goldmund), Emotiva, Aragon, Hypex, and Icepower, and they were all good amps, just no volume control of their own. I like the mixing and matching of component amps, and having a variety of them has exposed me to the ways that different amps can affect the sound.
Both of my preamps are quite old, and were already well used when I got each of them, and the SFL-1 was even repaired due to its age. I am wondering, who is currently using separates with a dedicated preamp, and what is considered a good modern preamp these days that people actually own? If you don't use a preamp, then what is feeding your amp(s)?
Hi, I am using a Levinson No. 28 as my system controller. Digital sources are WiiM Mini via Toslink to SMSL RAW-MDA 1 DAC via XLR to the No. 28. I set the desired max volume on the preamp and use the WiiM Mini volume to set listening volume. Analog sources are managed directly by the preamp. Works well. I have owned the No. 28 and No. 29 since new.
My preamp is a home-brewed 12 tube 2-box attempt at a minimalist audiophile extravaganza. It uses 12 6922/6DJ8/ECC88 duo-triodes with the sections paralleled to act as double-strength single triodes in 8 of them while the remaining 4, which comprise the line section, have the triodes used separately in one while the other has the sections paralleled. 8 of the tubes are for the phono section, with the remainder used in the line section. It uses reed relays for input selection, and these are controlled by capacitive touch buttons connected to latches to lock in the selected pair of relays, model CP-Claire 1A12 (one per channel per selected input). Relay coils are DC powered to prevent hum injection. A detachable umbilical cord connects the power supply box to the preamp box. Tube filaments are all powered by soft start regulated DC supplies, and power supply sequencing is used. That turns the heater supplies on, waits for a bit for the tubes to light up, and then kicks in the regulated HV supply. A bit later after all has settled out, a pair of normally closed relays activate and un-short the output terminals from ground. When the preamp is turned off, the output shorting relays are immediately de-activated to prevent a turn-off thump. I built it in 1987 and it is still in use. I'm on my second set of tubes for it, and all is still well. I call it ":His Reference". You pronounce the name of the punctuation mark (colon) when mentioning it. It accepts 3 different line inputs and a phono input, and has a tape monitor button that allows placing a device, such as an equalizer, for example, between the preamp's outputs and the power amps' inputs. Phono RIAA accuracy is within 0.5dB of the standard ( measured ). The two boxes have rack handles on the front panels, and these lend a serious "I ain't here to look purdy; I'm here to play fuh-baw (football)" look.
You can't tell us all that and not show us some pictures.
ME!
I use preamps:
(1977-1983)
Perspective
Sound
66 110 v15 Amp outlets? Glad you did not need one. I can't see a use for that many outlets other than super low amperage devices. 15 amps/66 outlets = 0.22 Amps per outlet all things devices being equal. (Not even counting the 14 USBS.)
Kinda cool though.
Need a preamp to run the hypex of the speakers and, as side effect, for measurements (RME ADI 2/4 pro SE).
Unlike some here, I like minimal systems and use a Mini DSP 4xHD as pre-amp...
CD player optical out to the Mini DSP. Output to subwoofer and power amp.
Volume control via remote of the Mini DSP.
ME!
I use preamps:
(1977-1983)
Perspective
Sound
My first receiver was an Advent 300. I fried the output transistors and replaced them myself.
Kinda cool though.
Naturally: it's a fake but it gets across the idea (in a humorous way)!
Also: Please note that the last word in the text for this SUPERDANA is Fire. As a featured use suggestion!
I even forced a divorce between the Audio and the Video parts of our entertainment system, so as to unburden my music back to it's free-range roots, where no one had ever heard of the words software and/or digital, in combination w/the word music.;)
Yeah, we now get new DACs being released weekly, but not many SOTA (ES9843Pro grade) preAmps and or ADCs.
My E1DA CosmosISO-A is a great testing tool but does not work well as a useful part of an audio system.
My Topping E2x2OTG Audio Interface gets much usage, integrated into my desktop audio system but it's useless w/o a remote (for a media center).
As good as the FOSI ZP3 performs as a decent preAmp in a media center, I have been waiting for a reasonably-priced SOTA (ES9843Pro grade) ADC or a preAmp since I dumped my Rotel AV separates (RSP-1576/RMB-1565 combo).
An SMSL DO100Pro is currently being used as the DAC that feeds the FOSI ZP3.
Recently, I ran across this weird-unit while surfing aliexpress and the price was so sweet that I was willing to gamble.
I was excited enough that I replaced my (media center's) current config (ZP3+DO100Pro) with this weird-unit that bears NobSound name as the PCB manufacturer.
This SDAC5.2 looked to have ALL of A/D connectivity that I needed (less an RJ45), without any of the fat that I did not want (like AES/EBU or I2S or MIDI).
TL&DR: It was a bad gamble: :(
(1) CD input for the right RCA ground (ferrule) pulled out along with the RCA cable
(2) If Optical input source is powered down, the SADC5.2 starts 'chirping' loudly
(3) After about 30 minutes of S/PDIF opto usage, the unit starts intermittently dropping-out the audio
(4) PC input (rear USB) appears to be part of the BT chipset and does not take priority...
I guess I have to go back to my ZP3+DO100P config, while waiting until someone comes up with a single chassis unit that does pre + ADC + DAC (with a DSP/EQ subsection).
Reactions: EJ3
ME!
I use preamps:
(1977-1983)
Perspective
Sound
That outlet strip matrix kind of makes me think of the faces in the audience the night that Stravinsky's Le Sacre du printemps premiered.
:cool:
I am (using a preamp).
(the bottom black box; top's an "HD" tuner :p )
I cannot be the only member that is waiting to see the de-contenting garage-sale you are going to have for all those (soon-to-be) ancestral audio gear.
OT: Do all of the switches on your Sangean HDT-1 tuner still work properly? When mine started going on the fritz, I just left it on the curbside. My Sangean RCR-3 also has similar issues, and I am thinking to make reservations for it on the same curbside.:(
