dude, give me everything in your brain please
thanks for all your responses
This is aiyima's explanation
so not all dissimilar to yours
@jlesterp in that, the power output hasn't been hindered and you need a higher input to get there
however, a) how was anyone suppose to know this, b) again, most DAC's commercially available are putting out 1.4-2Vrms, how is anyone making that higher? c) why now do we have to buy more equipment (wouldnt even know what to buy) to power an amp that at one point, was working perfectly fine with standard DACs?
i literally have 93db efficient speakers that i hooked this up to (DIYSG Volt6). At 6ft, i cannot calibrate to reference volume with a 2Vrms DAC without BOOSTING the digital signal (which would potentially cause clipping or hitting cLimiter in windows with EAPO)
EDIT: so some quick measurements, i have (2) 4.5ohm zister 20w resistors that i ran in series for a 9ohm load. on the rev 3.1, with 2Vrms (0dB on the E30 DAC, -3dBFS@80hz from REW) i'm getting 12.6Vrms output
on the rev 2.1 board, same setup, i'm getting about 21.4Vrms before i start to clip. note the volume knob is about 60% when this happens. if i push any higher than about 24-25Vrms, i hit some sort of limiter and it shuts down
on the rev 2.1 board, i maxed the volume on the amp, put E30 to -25dB, and pushed the volume up until i hit clipping around 21.4V which occurred at -10.5dB which measures 0.608Vrms of line output
since i have no way to get greater than 2Vrms of line output, i cannot get the required line it to max the rev 3.1
so it appears that in order to get max output:
rev 2.1 = 0.608V line input
rev 3.1 = unknown, >2V however
