chips666
Oeps..Am I missing something?
Sorry
In this case RCA splitter will do...
Meanwell EPP-200-27What is the Power Supply you ordered - Can you provide the link ?
Grounding problem again - not connected anywhere
To preempt the 'but it would be ok if they'd used a 2 pin mains connector' argument, look to the left of the circled pin at the clearance between the PCB trace connected to the mains, and the SMPS heatsink that's probably connected to the chassis. As I understand it that's insufficient to meet the rules for double insulation, so the safety earth really is required.Grounding problem again - not connected anywhere
.View attachment 121846
Hello! Any idea why A04 is more expensive than A07?
I need a budget amp for bedroom (so no loud listening), so first I thought about TPA3116, but it seems that 32xx are better in every way... However the thing that bothers me is a PSU. What bad can happen with the chinese ones? Can they combust when the amp is idle? I'm reluctant to spend on PSU 3x of amp price, would, say 2/3A PSU work for quiet listening?
It's not about being Chinese as such - many (most?) of the reputable, certified PSUs are manufactured there too. It's more that the cheap uncertified PSUs may have cut corners, and may not meet the levels of safety or performance you'd expect. With a bit of searching you'll find people doing tests and teardowns of phone chargers (one example) which should give you an idea of what can happen - I've not seen anything directly comparable for brick style PSUs, but have had some that don't meet spec for current output and others that do.Hello! Any idea why A04 is more expensive than A07?
Hi,
Finally did you test ? What about your opinion ?
You should try the OPA1692, I found this is the best OP amps for this module )
The cost difference between A07 and A04 is a slight difference such as the size of the power supply capacitor and the case. The rest is the difference in production quantity.Hello! Any idea why A04 is more expensive than A07?
I am interested in this amp board.The HanZao TPA3251 is now working.
At the moment I have tested it with 4558 and NE5532 while waiting for the OPA1692 to arrive. It sounds great and I hope it will sound better with the OPA1692. No background noise and no pop on power-on. But if there is a pop one second after power-off. I don't know if I could use some circuit to mute the amp at the moment of power-off.
View attachment 125013View attachment 125015
