I'm looking to get some subs for my room, say 70% movies, and wondering if I should go with 2 large (PB3000 for example), 2 smaller subs (PB1000 Pro) or some other suggestions, like 3 mixed ported with one really large, or even 4 sealed (SB3000) if the subs near the LR speakers need more clearance.
I can't get some brands like HSU but Monolith and Rythmik are a possibility. SVS are the easiest to obtain and don't seem as long as the others which helps.
Room dimensions are 16'2" W x 12'9' D x 8'10" H (1,820 ft3), with two proposed birds-eye layouts below (actually a 7.x.4 system but other speakers not shown). I can't really change the orientation of the seating due to WAF so it's going to have to do.
I have the two large subs at side mid-points, as size becomes an issue elsewhere, while I could squeeze in 4 x PB1000s if I use 1/4 points at the front and corners at the back. This would be a starting point for aligning with a miniDSP anyway.
Appreciate your thoughts.
