Which Purifi Amp to order
Hi, which one would you recommend from the pure price/performance, but still using the latest Purifi? Nothing fancy is needed, just bare sound. No fancy stage. And no issues, still going with flawless build. Shipping to USA.
I am using in desktop application, 80 Db max, no extra gain is needed, just stock option.
Find a used one from the previous generation and you're good to go.
(only make sure you get it from an extremely reliable seller with returning option)
@Sokel thanks no I don't need to risk, I am talking about brand new and reasonably recent model. My point is some builds are over 50 percent more expensive than the cheapest ones, and there should be a sweet spot somewhere very close to the cheapest.
Perfectly understood,I have the same mindset for used.
All been equal (Purifi modules+PSU) all that's left is input board flavor,looks,built quality and thermals.
If your application is how you describe it is not hard to choose,something in between like the Audiophonics one or the Apollon budget series should do.
I would go with the Audiophonics with the Purifi 7040 modules. Good balance of build, features and price.
Do you have to pay import duty to USA?
No import duties. I have ordered items from them. They ship via UPS. Usually two to three days for arrival.
I received my Apollon dual mono and beside the 2.5x longer lead time than they quoted, I’m happy with it so far.
hi, trying to understand current configuration- is there one that has XLR and RCA which can be switched, or is that one of the old models only?
We made one with XLR + RCA inputs and internal proper single to differential conversion, nobody cared. So we came back to proposing RCA to XLR cables.
