Hi, any updates? Are you happy with your new amp? Just out of curiosity, what speakers will this amp be driving? Thanks in advance.
Aerial:
I’m currently switching between a pair of Elac UF5s, and a pair of ELAC DBR72s. I couldn’t be happier.
Prior to this amp, I was driving these speakers, switching between an Aiyima A04, A07 and a Topping PA5. That said, I was leaning towards the DBR62s. With the added umph of the Audiophonics amp, it seems like the Purifi has the added punch to really make the UF5s sing.
I cut my teeth, years ago, on a Harman Kardon based system with a Citation 11&12 powering a pair of JBL L65’s. I have been conditioned to like my music loud and the new system really delivers nicely.
To be honest, the real difference between then and now is that unlike my HK system which was being driven from a nice turntable (Audio Retroflex, HK tuner and various cassette decks) I’m sourcing my new system from a Topping D 30 attached to a RasPi Zero 2W running Volumio and Sangean HD tuner so the music is ultra clean, dynamic and with wide bandwidth.
The resulting sound is just so crisp, clear and loud, mind bogglingly so. Too, you can really tell how far audio engineering has come over the past 50 years and old hits from the 70’s don‘t have the dynamics and bandwidth of materials from the 2000’s.
The amp runs dead cool. No startup sound
My only nitpic is the power switch on the front is bright white, too much so in my bedroom. (Built in nightlight?)
I’m in the States and ordering from France couldn’t have gone any more smoothly. Once in stock, delivery took less than a week. With the strong exchange rate, the price was right.
Ultimately, I plan to use this as my main amp on a Denon 9.2 home theatre installation.
I liked the case with heat sinks. Amir’s stellar review compared to other Purifi amps pushed me over the edge. To be honest, I had fantasized about one day taking the plunge for a Benchmark but that’s no longer on my mind. The AP amp has more power, has far fewer components to die in the long run and is as transparent as the Benchmark to my old ears. This is my endgame amp.
This new system really shows the good, the bad and the very ugly in source material.
If you’re considering an AP Purifi purchase, you have my highest recommendation.
