Keith_W
You know everytime i read an answer like this, there are 10 times more people out there that says things like "some amps sound more musical, richer, warmer, and musical Cleaner, more precise sound (thanks to lower THD)
You are right. We are a pretty small minority in this hobby. The vast majority of audiophiles think that amplifiers sound different. They are right, too - amplifiers can and do sound different. Listen to what Erin has to say about it:
Without getting too technical, some poorly designed amplifiers will change the frequency response depending on speaker impedance. Speaker impedance varies according to frequency, but also varies depending on volume and how much the voice coil and crossover components have heated up. So an amplifier that sounds "warm" on one speaker may not interact with another speaker the same way.
The bigger question is, why would you want that in the first place? Everything else - "warmth" or "richness" or what have you - is an addition created by the amplifier, that was not in the recording.
The reason why ASR is different is because we look at why some amplifiers perform differently with different speakers. We don't give subjective impressions, we look at data. Some of us with suitable equipment are able to test amplifiers. Being able to interpret the data is something else, though ... and IMO it's too much to ask a newcomer to learn how to look at those graphs and understand what it's telling you.
As long as the amplifier is in its linear range, has sufficiently low output impedance, and does not suffer from problems such as excessive noise or harmonic distortion - they will all sound the same. So the simplest advice to give is: get a well designed amplifier, make sure it has enough output power for your application (and thus keeping it within its linear range), and be done with it.
