I use rz50 and qsc dca 1644 amp.
Maybe I will get a nc502mp amp.
In this case, rz50 drive 4 speakers and preout to two or more power amps.
The qsc dca can change different gain.
Here is the question.
Should I just set the gain to max for all amp and just run the avr dirac to get auto balanced volume for all chanels?
I think each channel may have big different level settings after run dirac.
Or should I adjust amp's gain to match the avr's internal gain and let the all channel's level difference as small as possible?
Which way can get better sounds?
