Which is better, the SVS PB3000 or the SVS PB2000 Pro?
sysfc6
Which is better, the SVS PB3000 or the SVS PB2000 Pro? I’m thinking of buying a pair of subwoofers—which one is better, and is there a noticeable difference between them?
Have you compared their measurements already?
The Pro has built-in DSP with App control, so would be the better choice if you have no other DSP in your system.
你已经比较过他们的尺寸了吗?
[URL unfurl = " true "]https://www . audioholics . com/subwoofer-reviews/SVS-p B- 2000-pro-1[/URL]
[URL unfurl = " true "]https://www . audio holics . com/subwoofer-reviews/SVS-3000[/URL]
Pro内置了带应用程序控制的DSP,因此如果您的系统中没有其他DSP,这将是更好的选择。
are there any reviews of the svs pd3000r??
Always difficult to provide a recommendation when we know so little of the room, system, goals and EQ system.
My general recommendation is if in doubt and budget can bear it - oversize. That would be old PB4000 or new 5000 line. If nothing else, more headroom and less worry.
Both of those subs have DSP and the phone App. The 3000 series dropped the "Pro" designation because the sub is not offered without it
You mean the PB-3000 R|Evolution?
It's a new release, so no measurement review yet AFAIK.
Also, why am I your search engine? :p
Because people trust you more than Google? Status comes with few downsides as well...
Unless you have a pretty big room, two of either of those subs will give you bass slam. Just make sure they are in phase. If your walls are shaking and your having items move around on their own, you have just the right amount of bass. Long live the bass! LOL
Don’t they both have the same app?
