Don has a thread on bi-amping, including debunking some myths about supposed benefits of passive bi-amping. As well as discussing active bi-amplification.
This article provides a quick look at how bi-amplification works. The conventional scheme is to split the signal into two frequency bands before the power amplifiers that drive the speakers. The bass (LF) amp sees only LF signals and drives only the LF driver (woofer). The treble (HF) amp sees...
www.audiosciencereview.com
I posted measurements of a speaker to see if passive bi-amplification changes the sound, including the distortion. I used a 2-way with quite a large woofer at high-power at a bunch of different bass frequencies to try to elicit some change in the tweeter response, specifically to test the idea that somehow splitting the signals between amps actually changes the sound in any way.
Thank you Don, Is DENON addressing your point (#6) in their user manual? Yes. Whether or not bi-amping helps, or to what degree, depends greatly upon the output impedance of the amplifier, cable resistance (impedance), and speaker load (impedance). If the amplifier has low enough output...
Comparing mono- and bi-amping configurations, no change in sound, reduction of distortion, etc. No surprise based on what Don explains in the first post.
