Which graph is better
Darek K
Which is better : orange or red ?
Either colour... the thickness of the red line is the visual issue here.
JSmith
I am to fast.
Orange is sub after EQ in REW and minidsp with bassreflex open.
Red it is only my prediction what happens when I close bassreflex.
Simply "is it worth to do some efforts to close bassreflex and do next mesurments, next corrections, and next mesurments" ?
Closing the port won't reduce the overall level in the entire frequency range like that, it will reduce the level slightly in the low end of the frequency range, and at the same time extend the lowest frequencies a little bit.
This graph from a vented Arendal subwoofer might help you understand what to expect:
