Which driver ?
zag55
Hello, I wanted to ask you something. I use Jriver as my player, with the Topping E50. I can choose between Wasapi or Topping ASIO as my driver. Which of the two is better to use? Thank you.
There's no difference between ASIO and Wasapi Exclusive.
Both will transmit bit-exact and both will block other programs from playing sounds.
Wasapi Shared OTOH is different. That goes through the Windows audio pipeline and enables using Equalizer APO etc.
