AI sums it up pretty well. I always use this stuff for project work because you cannot melt the insulation while soldering and voltage ratings are high - very useful when building tube based guitar amps.
AI Overview
Teflon-insulated, silver-plated copper wire is a high-performance electrical cable known for its exceptional heat resistance, chemical durability, and low signal loss. [
1,
2]
Key Properties & Specifications
- Insulation: PTFE (Polytetrafluoroethylene, commonly known as Teflon), which resists melting during soldering and handles extreme temperatures from -65°C to 200°C (or up to 250°C peak). [1, 2, 3]
- Conductor: High-purity copper coated with a thick silver-plating layer, offering low internal resistance, excellent high-frequency (HF) conductivity, and superior aging resistance. [1, 2]
- Ratings: Typically rated for 300V to 600V depending on the specific gauge and wall thickness (such as MIL-Spec M16878 Type E wire). [1, 2]
Common Applications
- Audio & Radio: Widely used on platforms like diyAudio for point-to-point tube amplifier wiring and building high-reliability RF components like BalUns.
- Aerospace & Industrial: Used in tight spaces where accidental soldering iron contact might melt standard PVC insulation.
- Appliance Wiring: Internal wiring for high-temperature devices, sensors, and aerospace gear.
- Explore a spool of 24AWG Solid Conductor Silver Plated Copper, PTFE Insulated Wire from Skycraft Parts and Surplus.
- Read details on high-temperature hook-up wire at Remington Industries.
- Review technical specs for PTFE Hook-Up Wire at Allied Wire & Cable. [1, 2, 3, 4, 5, 6]
If you'd like to narrow down a specific type for a project, tell me:
- What gauge (AWG) you are looking for (e.g., 18AWG, 24AWG, 26AWG)
- What application or device you are wiring
- Whether you need solid or stranded core
