Black_Rabbit
- Joined
- Feb 19, 2026
- Messages
- 37
- Likes
- 13
- Thread Starter
- #41
Thanks!right length, meaningfully robust, OFC, right gauge. that is all that is needed. one does not need to overthink it
OFC isn't needed, ETP is more than sufficient.right length, meaningfully robust, OFC, right gauge. that is all that is needed. one does not need to overthink it
I know. I just like OFC and that is what I used for my DIY so I am giving my criteria I guessOFC isn't needed, ETP is more than sufficient.
There must be no distortion in the transmitted signal, and external noise must be blocked. I have made several LAN cables and connected them directly to wall outlets to listen to the results. I considered CAT5, 6, and 7, as well as whether or not they were insulated. Since long LAN cables can act like antennas by receiving external noise and affecting the signal, the cables must be insulated. I also take care to twist the cables and vent the received noise to the outside through the outlet.I modify my last comment, silver cables will definitely change your wallet. Unnecessarily. Audiophiles tend to be really crazy about stupid cables, which is very sad.
I generally just buy 12g speaker wire (copper and at least ETP, even OFC is overkill) and may add connectors for easy access/changing, covers a wide spectrum of potential use (speaker impedance, length needed). I don't need particular aesthetic, altho easy to do that on your own if you really need it, but paying for pretty cables tends to be very expensive at best. Your criteria is what, though?
So you're not talking about speaker cables, as I gathered from your comment about AR speakers above in comment number 41?There must be no distortion in the transmitted signal, and external noise must be blocked. I have made several LAN cables and connected them directly to wall outlets to listen to the results. I considered CAT5, 6, and 7, as well as whether or not they were insulated. Since long LAN cables can act like antennas by receiving external noise and affecting the signal, the cables must be insulated. I also take care to twist the cables and vent the received noise to the outside through the outlet.
Speaker cables and interconnected cables had relatively little effect, but I noticed a change in sound with LAN cables and power cables. So I began to wonder what kind of influence these cables could have.So you're not talking about speaker cables, as I gathered from your comment about AR speakers above in comment number 41?
Your comparison methods are likely more at fault. Changing audible sound via a digital connection or power cable is extremely unlikely (like speaker cable). You been reading hi end blogs/magazines or something as bad?Speaker cables and interconnected cables had relatively little effect, but I noticed a change in sound with LAN cables and power cables. So I began to wonder what kind of influence these cables could have.
These are the results of listening while connecting various cables I purchased. Although it may be highly subjective, I experienced a phenomenon where the background became silent while the sound became clearer.Your comparison methods are likely more at fault. Changing audible sound via a digital connection or power cable is extremely unlikely (like speaker cable). You been reading hi end blogs/magazines or something as bad?
Still sounds like a poor comparison method (which it just likely is, due the difficulty in doing a good one). Noise would more likely be just be the source, rather than cabling.These are the results of listening while connecting various cables I purchased. Although it may be highly subjective, I experienced a phenomenon where the background became silent while the sound became clearer.
This whole claim is highly suspect.Before I experienced it firsthand, I felt the same way as you all—wondering what role cables could actually play. It wasn't the interconnect cables or the speaker cables that made a significant change in the sound. It was the power cables. And not just any power cables; try connecting the best power cable you have to your source device, such as a network player or DAC. Back then, as if I were high on drugs, I connected the best power cable I could find to a Wadia 2000 CD Transport, felt a change in the sound, and decided to buy the cable. I still don't quite know why. Currently, I use a Mac Mini as a network player, connected with a custom-made power cable instead of the bundled one, and I am very satisfied. Well, it is all about self-satisfaction. Something I can experience without spending a fortune...
Cables—ah, cables, and which ones to choose. One of the topics ASR loves to (hate)-argue about. It’s fascinating, really, given that there isn't actually much to argue over—but there you go.This is a slightly different topic, but there was once a frenzy surrounding cables in Korea as well. I, too, got swept up in that atmosphere and once purchased a high-priced forged silver cable from the Australian company PSC. Ignoring the measurements, I paid a huge amount of money based solely on the two facts that it was forged silver and that air acts as an insulator. I don't regret the decision, but I still have doubts about whether cables really have a significant impact on sound. Since they are passive components, it seems like the best cable would be one that transmits signals without distortion and prevents noise interference... I do remember being fascinated when I occasionally built my own power cables and detected changes in sound on the same equipment. What is the right attitude to take regarding cables?
A bit off-topic—or borderline off-topic—for this thread, but since @Black_Rabbit is considering the new setup, why not? Regarding Atmos again: perhaps something worth trying after all:If you’re looking to try something completely new, why not check out music mixed in Atmos via streaming?
Mind you, I have no personal experience with it. I do know there are people who enjoy that kind of multi-channel mixed music, though I’m a bit skeptical myself. It might be good, BUT if the mix is just about chasing effects (like a snare drum popping up in the rear channels/speakers every now and then, for instance) it would probably just annoy me.
Atmos mixed music, that’s really a topic for another thread, though.![]()
www.audiosciencereview.com
This summer, I extracted all my four hundred or so 12" singles from the 80s and 90s and have played a good few now. The above was one of themAre they still going on about that "expensive DACs sound better" thing? How do they have the energy?
I say—or rather, Imagination says—it’s:
While cables made of Silver do not sound any different than copper, Silver does have an advantage. As it tarnishes, it maintains its conductivity. If Copper starts turning green, you get a deteriorating connection. The way I get around the Copper connection issue is to crimp the termination, then seal with solder.Silver is just silly. It doesn't change anything.
Or you could just cut the green stuff off and peel the insulation back to expose new copper....and copper even tarnished still retains quite a bit of conductivity....While cables made of Silver do not sound any different than copper, Silver does have an advantage. As it tarnishes, it maintains its conductivity. If Copper starts turning green, you get a deteriorating connection. The way I get around the Copper connection issue is to crimp the termination, then seal with solder.
Too much work. If I seal the copper termination with solder, I never have to touch it again. Silver plated copper gives you the best of both without the added cost of pure silver.Or you could just cut the green stuff off and peel the insulation back to expose new copper....and copper even tarnished still retains quite a bit of conductivity....
I'd never buy silver, there's no way its worth it at all. Tinning it would suffice, tho. It's just not something that's been a concern for me in many many years of using copper wire at all. Too much work doing it any other way than with good basic copper IME.Too much work. If I seal the copper termination with solder, I never have to touch it again. Silver plated copper gives you the best of both without the added cost of pure silver.
