It seems the music environment has changed a lot since then. I haven't listened to music for a while, either. Since network streaming seems to be the trend these days, ...
If you’re looking to try something completely new, why not check out music mixed in Atmos via streaming?
Mind you, I have no personal experience with it. I do know there are people who enjoy that kind of multi-channel mixed music, though I’m a bit skeptical myself. It might be good, BUT if the mix is just about chasing effects (like a snare drum popping up in the rear channels/speakers every now and then, for instance) it would probably just annoy me.
Atmos mixed music, that’s really a topic for another thread, though.
In any case, I’m mentioning Atmos since you’re considering new options; it might be right up your alley. If you’re already into home theater, you’re kind of on that track already, so to speak.
(Gemini AI)
My main system consists of Wilson Audio Watt Puppy 5.1 speaker system,
I just noticed which speakers you have. They’d probably benefit from a bit of a boost across the frequencies below 1 kHz (or maybe not—that is, if you have them placed close to a wall)—something you can easily handle with EQ.
You’d also want to use EQ to address the issues caused by those pesky room modes*.
There’s a choppy frequency response from 15 kHz upwards, but you might not be a youngster anymore?—so perhaps that’s a range you can’t hear anyway?
Bringing down that peak at 9 kHz by a few dB might yield an audible difference, though. It can produce good results if the on- and off-axis responses track smoothly. It’s just a matter of testing it out and listening.
Sidebar 3: Measurements Coupled with a very high sensitivity—calculated at 91dB/2.83V/m (B-weighted)—the impedance of the Series 5 WATT by itself (fig.1) is definitely kinder on amplifiers than the earlier versions. Its minimum value is 5.2 ohms in the lower midrange, and the phase angle is...
www.stereophile.com
https://en.wikipedia.org/wiki/Room_modes
