Which DAC measurements do you like to see next?
SIY
Alfred, NY
In the primordial past (college, early 1980's) I used a fairly small box (about an 18"~24" cube IIRC) lined inside with absorption to measure near-field performance over most of the frequency range. Bass response was tough without a real anechoic chamber (which I had access to at the time; these days, the local college has a nice one, but I'd have to pay to use it or rope one of my friends on staff to help). The box when sealed had a pretty low noise floor after I wised up and suspended the measurement box within a larger box with thick walls and so forth to better isolate the measurement box from the outside world. And tended to test later at night when the building was quieter.
The bigger problem for me was getting a source that was known good over a wide range of frequency and dynamics. The good measurement mics often outdid the drivers used to send test signals to the mics. I had some piezo and compression drivers that were OK from maybe a few hundred Hz but sub-100 Hz I am not sure I was ever satisfied I knew what was limiting the measurements. My Earthworks was good to 5 Hz and at that time I had no good low-distortion driver flat to 5 Hz around.
But again, not my day job, so I was probably just being ignorant, or stupid, or both...
Or too early to the game. The key to getting good midband and HF measurements is gating the impulse response, which wasn't easy in the early '80s unless you were lucky enough to have Nicolet FFT gear (the NIC system I used then was >$100k). You do need a calibrated reference mike (I based my measurements off a B&K 4133 for most of my reviews, but have a new reference now). Ditto your sound source- it doesn't need to be flat, you can normalize it out. You do need a way of getting the diaphragm position repeatable for substitution, in my case a hanging string and golf ball, which are secured out of the way during measurements. A turntable with the diaphragm centered will allow you to get polar pattern data.
Noise floor measurements require isolation, either something like your box or, if you really want to plumb the depths, the BLANK chamber I use (which has allowed me to measure noise below 5 dB SPL).
Distortion is best done at a moderately low frequency in a nearfield setup. Most cheaper test mikes which otherwise look fine for frequency response fall apart in this test. Some expensive ones do, too. Here's a good expensive one versus a superb expensive one:
alex.r
It would be amazing if you measured Realtek ALC 1220 on some respectable mobo brand and compared it with super-duper-audiophiliac stuff. :)
Interested in these measurements too.
Personally use Asus Gene VIII which claims:
or some of the latest their stuff like - Asus ROG Rampage VI Extreme:
Also would be great to see some measurements of some cheap and known Raspberry HAT DACs if it's suitable for audiophile forum - maybe a few in the way of comparison like:
1. Hifiberry DAC+ PRO (TI PCM5122)
2. iQaudio PIDAC-PRO (TI PCM5242)
3. Allo BOSS I2S DAC V 1.2 (TI PCM5122)
4. JustBoom DAC HAT (TI PCM5122)
5. ST4000 DAC ES9018K2M HDMI I2S TCXO (ES9018K2M)
6. AUDIOPHONICS I-SABRE V4 DAC ES9023 TCXO (ES9023)
7. AUDIOPHONICS I-TDA1387 TCXO (TDA 1387)
8. AOIDE DAC II ESS ES9018K2M I2S DAC (ES9018K2M)
9. AUDIOPHONICS DAC I-Sabre ES9038Q2M KALI EDITION (ES9038Q2M)
Thanks for your work.
Dialectic
a fortified compound
I'm perplexed by the marketing in the bottom ad. I'd be surprised if the mobo has discrete mosfets to power the headphone jack.
It would be rather challenging to measure one of those mobos because you would have to build a PC around it first!
Wow, I didn't realize Motherboard people were going that far in their audio solutions. I have something fancy on my desktop unit which I will measure at some point. :)
Welcome to the forum by the way. Good first post. :)
duo8
It's interesting to see something that doesn't use realtek for once.
Unless "S1220" is another one of those realtek chips that never made it on their website.
Elix
Amir, I'm basically checking this forum every day to see some portable DAC/AMP or DAP measurements from you :) While SMSL Idea is a good DAC, it is on par with my phone (Highscreen Boost 3 Pro with ES9018K2M + OPA1612). There are some interesting entries around:
DAC/AMPs:
SMSL IQ
Toppind NX4 DSD
iFi Audio Micro iDSD Black Label
DAPs:
F. Audio FA1
iBasso DX200
Oriolus DP100
xDuoo X20
dheepak10
I have this one on loan so review will be coming. Just looking at it, it looks pretty nice!
I have the silver one of that. Will you settle for it?
Looking forward to NX4 DSD measurements
ifi nano iDSD black label by any chance? :)
These two are my shortlist for portable DAC/AMP
Does anyone have one that wants to loan it to me for review? I have the silver one and don't use it. Hate to have two of them then. :)
mindbomb
Gamersnexus is a youtube channel known for their deep dives into computer hardware. I think it would be cool if you guys teamed up to cover the current state of motherboard audio - he probably has a bunch of new motherboards you can test.
https://www.gamersnexus.net/supportgn/1200-contact-us
Good suggestion. I just fired off an email to them. It may not hurt for some of you to express the same desire to them as common readers of both sites. :)
Ron Texas
Rather than start a new thread, I will mention here that I just received an ifi nano idsd black. It drives HD650's to uncomfortably loud levels (for me) but not first row rock concert insane, will cause hearing loss, levels. While advertised as DSD256 capable, it will only do DSD128 on a Mac. I believe the only way to get DSD256 out of it is on Windows or Linux with an ASIO driver with native DSD (not DOP.)
I bought it to use in a nightstand setup with a Macbook Pro and an external USB 3 drive. It's a single box, single connection solution. Space is less than a desktop and I did not want a mess of wires, boxes or heat producing tubes. It is easy to pick it up in one hand with the external drive.
Subjective SQ:
Hints of chocolate, raspberry, tobacco, oleander, hemlock, Tide pods, and Drano. I think you get it.
I am looking forward to seeing the measurements. I hope they are not Schiit.
maxxevv
In other words "coloured and not anywhere near transparent" ?
My guess is that it would measure somewhere in the middle of the road. Not crappy but not best-in-class either.
dheepak10
Subjective SQ:
Confused between this one and the NX4 DSD from Topping in the absence of measurements
Ron Texas
Delivery times on the NX4 are long. You can have a nano black label in your hands in about 3 days. Buy from someplace with a liberal return policy and send it back if you don't like it.
Simon740
Hello,
Im new on this forum and it will be Nice to see measurements for LKS 004 Sabre 9038 pro.
Regards,
Simon
palamudin
Fast search of that device (LKS) netted a discovery that all ESS chips are garbage (as per SBAF membership), that R2R is the real deal and that Schiit is so good every household should have one. I can already hear my device playing worse. Must resist urge to buy 5k dac.
palamudin
I just started a thread over at HF on the SMSL VMV D-1. Its also a dual ES9038PRO setup. Would be interesting to see what comes out of it though!
http://www.smsl-audio.com/productshow.asp?id=146
The promotional text on the page is hilarious. Why is it so hard to find a translator to get their thoughts into proper wording. Tho device itself looks like a beast.
