Which combination: Simgots EA500LM vs Truthear Zero: Blue2
mrlawrencelam
I mostly listen to pop music and like slightly stronger bass (but not the heavy rock type). I also listen a lot to sentimental female vocals. I can’t make up my mind which combination below to choose:
(A)Simgots EA500LM + Simgots DEW4X dongle + Calendula 24-Core 4.4mm 0.78mm Balanced Cable + Honor Magic 8 Pro smart phone (on Spotify)
(B)Truthear Zero: Blue2 + Dunu DTC480 Pro dongle + Calendula 24-Core 4.4mm 0.78mm Balanced Cable + Honor Magic 8 PRO smart phone (on Spotify)
B
Welcome to ASR! You can decide on the IEM and dongle independently. IEM-wise, both of your options seem to have a pretty common Harman-like tuning. You can compare them here. The Truthear Zeros are often recommended on ASR, though most people seem to prefer the Zero:Red. While the frequency response is the most important factor determining the sound of an IEM, the measurements are taken on a standardized test rig and not your head. So the graphs give you a general idea of how these IEMs will likely sound, but in the end you will need to test them in your ears with your preferred tips and possible EQ.
Concerning the dongles, I would personally stay away from anything using Cirrus logic CS431xxx chips unless you can confirm that the specific model you're looking at does not have the known DRE flaw. Other options include cheaper dongles using a KT02H20 chip like the JMCally JM6 or balanced devices like the Fosi DS2. Many more are listed in the review index (search for device type "dongle"). Concerning the cable, you can buy that balanced one but you should consider that it gives you pretty much zero advantage in an IEM. Balanced cables offer 4 times the power, but IEMs are super efficient and you are almost never power-limited. There is a theoretical advantage in crosstalk, but I don't remember seeing any test or measurement where crosstalk in a single ended cable has been shown to be problematic. I would rather spend that additional money on a better dongle with EQ than on a cable.
I had the original Blues, and I wound up giving them away. I also have the EA 500 LM's, and they too are kind of bright, but tunable with all the options for nozzles and rings, but even so, I found myself needing to EQ them to get them to sound right. But once tuned, they do sound better than either the Blues or the Reds IMHO, and they look higher quality with the metal shells. I would recommend Devinus Velvet tips with them. But my fave among the lower priced entry level are the 7hz Crinaclce Zero 2's. I think they are just about perfectly tuned with only slightly too much sub bass. A minus 2 d low shelf at 200 hz will make them just about perfect.
both are too contrasty and bordering on splashy and zingy in the treble. good bass on both.
What is your budget?
You will only know what either of IEMs sound like when in your own ear. Ears vary like rooms, so don't worry about specs., curves, recommendations etc.
You don't need a fancy cable; it makes no difference that you are likely hear, unless something is poor about the dongle or phone supplying the signal.
Bottom line - pick an IEM, don't overpay, and if not happy give it away and try another. I'm sure the media app on your phone has EQ that you could play with.
