Hi guys, and one girl
I am trying to find the right, ideally cheap streamer for a stand-alone DAC. It is said that if I take a streamer without USB-out, then my expensive DAC will receive the potentially worse clocking from the streamer, and basically not re-clock it DAC-internally. Is that even true?
So my initial plan was to get the cheapest Wiim Pro, just for streaming, and connect it to an Audiolab D9 DAC. But in light of the above, and since the Wiim Pro does not have USB, and only the most expensive Wiim Ultra actually has USB, now I am thinking that I basically have to take the plunge here, simply for the sake of USB. The Ultra also has the much better ES9038M2Q chip. - But before I start spending any money, I wanted to get clarity as to where my music really gets clocked, i.e. is that USB-narrative correct? Obviously, I want the DAC to clock it. There is even the suggestion to get an SMSL PO 100 for only 60 bucks, as it supposedly has a better clock than the Wiim Ultra, and put that between streamer and DAC, again via USB, to make use of its claimed superior clock. Is that all nonsene, all good advice ?
