Which balanced cable do I need to connect a Focusrite Scarlett 2i2 to a pair of KRK Rokit RP5 G4?
Thunder
Lambda
Yes. looks right to me
but i don't know this brand and maybe your overpaying...
Somafunk
Scotland
Its the correct cable and I expect it’ll do just fine but I’ve no experience of the build quality of those Tisino XLR’s, I’ve always used Neutrik XLR’s and should only cost you a few $ more for a similar length
Thunder
Thunder
Thanks for your answers! I'll look into other brands then :)
Blumlein 88
The ones you linked to are likely just fine. If you wanted Neutrik connectors and Mogami cable these are some good ones.
Thunder
Thunder
Thank you, friend!
Lambda
~10€ is already what i would consider premium
Thunder
Thunder
Awesome.
