Which Aiso for Minidsp Flex and REW
Richx200
Working on aligning 4 subs with a Minidsp Flex 2x4 and REW. Is there a preferred Aiso to use when taking measurements for the Minidsp console?
My choices are MinidspAsio, FlexAsio, or Aiso4All.
Sometimes the input and output are hard to configure.
Thank you for your time.
USe Java Excl. (Wasapi) drivers if you can, a lot more friendly and almost as low latency.
Mmm... Wasabi.
Gotta mix in soy and have some ginger then too surely?
Would Java work will when it comes EQ filters for the Flex?
Sure, driver type has no effect on that process. Use these settings for auto-EQ and saving filters in REW and you will get biquads ready to be imported by Flex:
