Where to plug in Sub?
kenmasters007
Hi, I’m new to the forum. I recently picked up a pair of Topping B200 monoblocks, paired with a Topping Pre90 and an Octo DAC8 Pro DAC, driving Wharfedale Super Lintons.
I’d like to add a bit more low-end bass to the system. Since the B200s don’t have sub outputs, I assume I would connect a powered subwoofer to the line/preamp output on the Pre90. Is that the correct approach?
Would pretty much any powered subwoofer with line-level inputs work with this setup, or are there particular features I should be looking for?
I’d also appreciate any recommendations for subs that would pair particularly well with the Super Lintons and the rest of this system.
Thanks!
Hi @kenmasters007! Welcome to ASR.
Yes. As long as you connect the Sub downstream of your main volume control, you're good.
For the best performance, look for a DSP sub where you can configure level, phase, delay, crossover, and a few PEQs for the best integration with your mains.
Apart from that, all the usual Sub performance characteristics like bandwidth, CEA-2010 output, Group delay etc.
That depends a lot on your budget, which country you're located in, and whether you have any restrictions in the size or number of subwoofers.
Thanks for the quick response! I'm in Canada. Thinking of just one sub. Budget is tough question. I rather not overspend if I cannot hear the difference.
For a small room, I asked GPT and it provided me with these suggestions: SVS SB-1000 Pro, Arendal 1961 1S, Paradigm Defiance S10.
You'll need a sub with built-in low-pass filter for the sub and a phase/delay adjustment (not just a polarity switch) for best integration. It would also be best to add a crossover so the main speakers are high-passed to reduce their bass load; offloading deep bass from the main speakers is one of the advantages of a sub. You can buy a sub with a high-pass output (like one of Rythmik's models, which I use, or one of the other brands) or buy an external analog or digital crossover. Time delay or phase adjustment in the sub is used to align the sub to the main speakers so they are working together instead of fighting each other.
My usual starting point is to put the crossover an octave above (2x) the main speaker's -3 dB corner, e.g. 80 Hz if the main speakers have a 40 Hz low-frequency limit. That offloads bass from the main speakers and provides room for the crossover to work, simplifying integration.
Super Lintons have -3dB point at a claimed 39Hz.
If you don't have a means to measure responses and set up EQ, you'd arguably start by setting the -3dB on the sub at ~39Hz too, and playing a test files with bass sweeps or steps from say 20 to 100Hz. It's test and fiddle I'm afraid, setting sub volume each time you change XO point - you're looking for "boominess" or "suckouts" - if the former is around 39Hz, you should try dropping the sub's XO point a little, and vice versa. You will likely notice boom & suck at other frequencies too - these are room modes, and if bad, you may need EQ, but lots of soft furniture, rugs, etc can help. A wife is usually good for room treatments :)
Another experiment is to foam-plug the rear ports on the Lintons, which will push up -3dB point on them, allowing the subs to XO at a higher frequency. You still have to repeat all of the above though. This port-plugging works very well for my setup, but mileage varies.
Lastly, when the neighbours come round bearing torches and scythes, you may want to stop the loud bass sweeps and try some actual music, but bear in mind a surpsiing amount of music has little content below ~40Hz (~bottom E on a bass guitar). You need big organs (ooh, Matron!) or synths or movie explosions to really test the bass end.
I was wondering the same thing. The connection options can be a little confusing at firs…….thanks for the helpful replies here.
