Where from does the clicks come in this "unhearable" file?
tomtoo
Germany
I realy wonder. Would be nice if someone could explain?
It's 7clicks that are hard to explain for me why they are there??
  • sound.zip
tomtoo
tomtoo
Germany
It's the discontinuities where the 20 kHz bursts start and stop.
Yes that's somehow clear, but what do they do that i can hear them? Even that only 6db louder two sampels in the first burst i hear as a click.
A signal i cant hear starts and i can hear it starting. Isnt that strange?
Edit: This all started couse i had a discussion with a friend about transients and what we hear.
Now i feel very unshure.
mansr
Hampshire
Any discontinuity results in a wideband click similar to an impulse. The portion falling in the audible frequency range is, well, audible. Blame Mr Fourier.
tomtoo
tomtoo
Germany
Ah ok it's Fouriers fault. ;) It would be cool if someone could explain this in words.The Problem is i have no clue about fourier transforms and math harder than ±×÷.
SIY
Alfred, NY
Basically, you get a frequency domain spectrum that has harmonics at multiples of the repetition frequency. So if the repetition rate is low, the harmonics will be pretty rich in the audible range. Limiting case: a unit impulse of a width that approaches zero time has a frequency spectrum that includes all frequencies.
This tech note explains tone bursts pretty well. Skip though the baffling math and concentrate on the conclusions.
https://ietlabs.com/pdf/GR_Appnote/IN-105 Frequency Spectrum of a Tone Burst.pdf
tomtoo
tomtoo
Germany
"...Limiting case: a unit impulse of a width that approaches zero time has a frequency spectrum that includes all frequencies..."
Can understand this like this jumps are like a pulse that include a lot of frequencies. The shorter the time the more frequencies included?
SIY
Alfred, NY
Exactly.
tomtoo
tomtoo
Germany
Ok, thx this explains why you can hear them also in a woofer?
Edit: Sry for my not so intelligent questions but thats hard to understand intuitiv.
SIY
Alfred, NY
Yes. Let's say the burst is repeated four times a second. Then you'll get components at 4, 8, 12, 16, 20... Hz, definitely in woofer territory.
tomtoo
tomtoo
Germany
Thx have to read that pdf from you. And again thx a lot for your help.
Reactions: SIY
Pluto
Harrow, UK
And here's how it could/should have been…
I'll leave it to you lot to work out what I've done ;) Up yours, Monsieur Fourier!
p.s. I've deliberately left the really big click in there
  • 20 khz as it should be.zip
tomtoo
tomtoo
Germany
h
Thx! It's not i couldnt do this. It's more how this click happens. Shure i could fade in. But i try to understand what happens with that click. And looks like Fourier told this already. The problem is his language you know. And not the french that would be solvable, no it's the math. ;)
tomtoo
tomtoo
Germany
Somhow it's funny how this interest started.
A friend of mine had a small canton speaker. And he bought a kali-lp6. And his impression was the kali sounds in transients slower not as clear as the canton. So his conclusion was(couse the canton go higher in FR) that a tweeter has to go far over human hearing to sound right at transients. Iam skeptikal about this. But....i dont know??
I would appreciate any help to solve this question!.
Edit says: Both speakers where linear eq'ed on axs.
Pluto
Harrow, UK
I haven't the time to check, but I wonder to what extent your original file contains frequencies above Nyquist i.e. as though a suitable anti-aliasing filter had not been used?
A useful rule of thumb in audio editing; no transition less than 5mS!
tomtoo
tomtoo
Germany
No it's as i know just raw generated tones in audiacity and clued thogeter. thx! for the rule, but the clicks are what i like to understand.
Edit says: You know with my rudimentary audio underständig it's hard to get why? To get ride of them is not the problem.
bennybbbx
germany
I have done a 96 khz sample rate version and 2 samples as klick.with music it es better to check speakers. My theorie is speaker or headphones i own are bad. the lowest level and shortest click i get with canton alu mangan 40 khz tweeter. kali LP6 do a much louder but longer more lower freq click. Is somebody here with high end speakers and can please test with a Adam AMT or a DT 770 DT880 if he can her the click too ?. i have measure microphone and i record the kali output too. it boostet the click alot. and the best is the marshall DSL 5 CR. i put mixer in FX return in the amp and play and record the 20 khz tone. it have a 10 zoll celesetion speaker. the speaker play the click loud and fat and long. the 20 khz tone is play from 10 zoll speaker, but it can not hear. so a real good speaker should produce the click so it can not hear
the 2 samples 6 db higher are at a rate at 48 khz. this is really strange wy this can hear or very short i think EDIT: in the attached file zip is a screenhot that show how waveform look. if the speakers are not bad when click can hear then only other possibility is that ears can hear transients much shorter than tone hear period time
  • 2 smp 6 db louder at sr 96 khz.zip
Pio2001
Neuville-sur-Saône, France
Maybe the sonogram of the file can help you :
What we hear are the vertical blue bars.
tomelex
So called Midwest, USA
I would say what you hear are the audio frequencies of your speaker trying to follow the signal, and not being able to, to put it simply your speaker does the best it can to respond to the electrical impulse, and it makes a pigs breakfast out of it.
