Where does EMI/EMC, leakage current, common mode noise and other considerations belong on the "audibly the same" discussion?
Does it affect the digital communication between the PC and DAC. Or the analog signal between the DAC and the amp?
The latter - it is that "common mode" noise again, caused by ground currents in the 0V connection of the interconnect. If that interconnect is unbalanced then the noise will simply be added to the signal at the receiving end. When the source of noise is a PC (one of the most common sources IME) then you can frequently hear the effects of graphics changes, or mouse movement.
Of course - if the noise were severe enough, it could potentially disrupt the digital comms between PC and DAC also - but I've never experienced this.
But while it is commonly used as 'ground noise', it is not. The noise is not being generated from the 'ground'.
Agreed - it is noise created from currents flowing in the ground loop. The source of those currents can be leakage (as you've pointed out), or magnetic coupling from H field passing through the loop. Probably many other mechanisms that fail to come to mind right now.
The closest radio tower to me is my neighbor's roof. :)
P.S. European regulations and certifications are rigorous.
And yet, common mode noise exists in systems which inherently do not have ground.
Perhaps you are objecting to my use of the word "ground" for "local 0V reference" or "shield"" which most commonly (or should be) chassis - even in ungrounded equipment if it is going to comply with AES 48.
But my statement was also specifically referring to ground loop noise. If there is no ground connection downstream of the receiving equipment (and no other loop back to upstream equipment) then there is typically no ground loop. So of course that mechanism for creating common mode noise doesn't apply.
Why do I feel most of your replies are intended as "gotchas". That "Hmmm..." was particularly telling.
I think I'll bow out of your discussion now. It is not of the style I like to participate in.
I inherently have to point out that whether or not it is 'ground currents' is an assumption. For example, what if it is a laptop with a Type II power supply? What is all three devices are Type II?
Additionally, the input reference of an unbalanced connection need not be chassis. It simply is unfortunate that is how the audio industry implements it.
Perhaps we should not simply accept DACs which are highly susceptible to reasonable levels of common mode currents/voltage?
Reasonable being those which remain within the allowable level of consumer regulations?
Obviously, there will be some level where it is unreasonable to expect compatability.
What about the constant injection of some unnamed bugaboo into discussions?
I find that a rather unscientific cudgel.
Someone wants an argument. Should go to the correct room.
I don't have any gear with a filter integrated into the IEC receptacle. I'm not sure Ive ever seen any home AV kit that has.
me neither, those receptacles are relatively expensive and might be overkill when the goal is to comply to conducted emission/immunity. Chances are some simple filter components inside the gear on a PCB are sufficient and better suited for the job at hand (which usually is emission, not immunity).
There might be some gear that uses those and vaguely remember seeing one in an expensive amp design but is rare indeed.
What is more common is an inlet with an integrated fuse.
They receptacles with integrated filter (properly screened all the way to the output) will very likely outperform the filters found on any SMPS.
Rather, I would wager that it generally involves a effects of leakage currents of one or either device causing common mode noise..
agreed.
Safety ground does not equal ground.
I would postulate that any piece of equipment which may suffer susceptibility issues with common mode noises which fall under this level *IS* an improperly engineered piece of equipment.
Then almost all (home) audio equipment is improperly engineered.
Frankly I am amazed how often connected gear using RCA interconnects works as problem free (no audible noise(s)) as they do in practice.
Another thing is that only the people that have 'weird' issues with gear ask for advice on ASR about these issues.
Mostly the problem is solved by USB isolators or some grounding or connection errors.
Hardly ever by buying other gear (although this also can help) or modifications to existing equipment even is that is 'improperly engineered'.
Lift the ground, voila!
Not always, class II by definition is not grounded (to safety ground) and also not needed from a safety standpoint. Ground lift could help or make things worse depending on how and where leakage currents travel.
I agree on 'isolation'. However, the fault may not be due to a 'lack of isolation'.
In the vast majority of connected DAC issues they usually are. Of course there could also be an issue caused between mains fed DAC and mains fed amp for instance which won't be solved with galvanic separation between DAC and digital source.
This too will likely be an interconnection issue that might not be happening with the same gear used by someone else.
Its 2025, any USB DAC which is not comptable with common computer hardware is just poorly designed. IMHO.
It could be a connecting issue or some computer hardware/firmware/software that is at 'fault' as well, doesn't need to be the DAC itself which might or might not fully comply to the different USB standards the DAC might be connected to. The choice of DAC could solve that though. For instance a DAC that requires USB3 and draws a higher current than some laptop/phone/tablet or USB socket (USB splitter in between for instance) draws could be a reason for a DAC that is USB3 compliant not to work with some USB2 'compliant' devices.
Weird, I would have hoped the collective expectation of audio equipment buyers would be that the equipment they purchase would be compatable with the other equipment when featuring the same type of interface. e.g. USB to USB, RCA to RCA, XLR to XLR, toslink to tosklink.
Usually they are problem free (surprisingly)
With RCA, however, there are no standards and even toslink to toslink not always works above certain bitrates even if they do on other systems. For instance the LED in the transmitter may well have degraded in power output or there is something wrong with the POF cable or production tolerances (or changes in receiver manufacturer) may be the limiting factor.
USB to USB also isn't always fully compatible.
People expect that... sure. Practice often thinks otherwise.
I seriously wonder how many people have brought products to 'fix' preexisting problems in equipment which ought not to have it?
Yep, that will often be the case. Mostly based on reviews or well intended recommendations.
I would even go further and say how many people have bought certain products simply to prevent 'gremlins' to occur which were not needed in the first place.
That's the price one pays for not knowing. I reckon even most engineers do not know what is needed and what not.
I mean... not every one has a meter and would travel with the required type of meter(s) to debug audio issues and know what and how to debug.
EMC is quite tricky, sometimes even for EMC engineers that travel with a bunch of filters, ferrites, copper tape and whatnot.
Usually it is just leakage currents and the usual bag of EMC tricks might not solve anything.
Might I point out that this is a new thread?
Yep, but we all know where this thread is a spin-off from given the examples you gave. :)
Perhaps start a thread named 'what about leakage currents' for instance. And preferably offer possible solutions, measurements showing the issue etc. That helps people more than just blaming audio measurements missing these issues and desiring audio companies to 'design keeping all possible mismatches and problems in mind'.
Good engineers trouble shoot and offer solutions to problems. Not all gear is well designed to operate on all conditions that may or may not have been tested in practice nor rule out possible incorrect connections in the literally infinite possibilities of connections between gear.
The name of the thread title needs some clarification as well.
Would gear that performs the same (in audio quality) but has added some 'audible gremlin' (so severe enough to reach audible levels) still be audible transparent (as in performance) ?
Who determines when sound quality is found to be degraded by 'something' and how is that determined ?
I mean people hear differences when they wrap spiralit around the main water piping or connect a box with sand to something and hear differences that are so obvious that an AB is not even needed. Do those individuals qualify ? Even when they reduced some common mode current that does not even cause audible issues.
This too is an aspect of the thread title that can be discussed.
The same issue that causes some 'disturbance' of the audio signal may or may not reach audible levels (yet be present) and not everyone is equally bothered by an issue that potentially could be solved but requires effort and investments.
Does it have a legitiment scientific place in discussions of (possible) audible differences?
Show us the scientific studies. There are not many. Any audible differences are from faulty design of PS and filters. The only places where there is a issue is in hospitals and labs where there can be interference with sensitive monitors and other such equipment, not audible but electronic. These things can be handled with adherence to IEC 60601. Please bring some data and stop trolling.
Reactions: MAB
So, my semi-recent experience which kicked this all off for me was figuring out issues I had had my Topping DX3Pro+. It worked without issue on my Dell PC, but not on my MS Surface. Sometimes it worked great, but other times it would make faint but clearly audible metallic or scraping clicking sound. It generally occurred when using the mouse (wireless), during movie scenes with abrupt dark to light transitions, but the worst was when touching the screen.
Yes, a generic USB isolator development board stopped the issue. Or at least rendered it low enough that I do not notice it. But that is not satisfying to me.
Knowing both are of the two-pin plug variety I figured it was related to the lines-frequency related leakage currents causing common mode current flow between the two devices. But, interestingly the difference between when it working fine and not, was the rotation of the power plug. I not sure I had contemplated under what conditions the polarity of one relative to another would matter. Large amounts were bad either way.
So here are two sets of measurements of power-mains induced common mode currents, with four curves each. Black is the voltage Line to Neutral which I used as a phase reference. Yellow is the leakage current from the Surface's USB shell to Neutral when unconnected to the Topping. Green is the Topping USB shell to neutral by itself as well. Blue is then the induced current flow between the two. Note: this was not taken simultaneously with Yellow and Blue.
The first chart is when the leakage currents of the two are "out of phase" with each other. They sum to a peak amplitudes of +176 uA -114 uA. The second is when the polarity of the AC power has been flipped on the Surface, and now the two are 'in phase' with amplitudes of +100 uA and -87 uA. Note: the currents are "positive" when thet flow from the device to Neutral.
I would easily believe the sounds may still be there, just simply low enough that I do not hear them.
The long term solution has been to add a ground plug and wire connected to an exterior screw of the Topping using a ring-crimp.
But I find it rather irritating that they co-mingled analog signal returns with digital "ground" and then chose to use a Type II power supply.
That's not a robust design.
Note: A portable Rohde RTH scope was used for the inquisitions.
This forum is replete of examples of clearly audible effects, so I reject your demand for a scientific study as it's self evident.
However, I do agree with you in part. Most those audible hums, noises, etc. are due to faulty design. They just are too often just accepted.
So true, but there are studies of audible ranges but few are related to playback devices. This is because these studies require rigorous double blind study designs, high number of participants to reach a low P-value and by the fact that what a 16 year old hears and 66 year old hears are vastly different. The fact that you assert that audible ranges are obtained from "EMI/EMC, leakage current" implies that they are there without any evidence and also indulge in circular arguments without evidence just brings the ire of other members. I am not expert on the subject, a ME that has worked on high powered electronic equipment that was used in surgical suites and cath labs where sensitive monitors exist and have some familiarity with this issue, but not electronics design. The convention in audio is to look at THD, IMD and such which are widely accepted in audio design.
If you object to my position on general causes of the common audible issues that would be one thing.
But seemingly denying audible issues exist is all together different.
I agree with that and have asked Amir to put 20 year old audibility lines on the appropriate graphs in some of my other posts. But he often cites when bad test data is approaching the audible ranges, which because it does not, is rare. SINADE for example is around below 70 dB but rarely is any modern device that low. I can not tell you what study that was derived from and that is a general omission at ASR.
I made a tutorial on this 10 years ago,
Is Amir explaining one of the effects possible from leakage current sufficient for you? ( Using Bill Whitlock's AES presentation slides )
I would wager many here would call that a "ground loop" or "ground hum" as well. Even thou neither ground, nor the electrical wiring tied to ground are involved!
Note: to explain why I often say "Mains induced leakage current" it is to specifically refer to the leakage current related to the mains fed AC/DC power supply. A device may also have other DC:DC power supplies which in all probability do not involved 60 Hz or harmonics.
Awesome :)
I'm very glad to know I'm not the only one hearing things ;-)
Well done OP, you have used a USB isolator to remove the (slightly) audible noise from a mouse being operated.
Now explain how a meter or so of mains cable achieves this.
"There is an intangible sense of musical flow. The more microscopic my mind wanted to get in deciphering it, the more baffling the way Leviathan evokes aural magic directly connecting to the right part of the brain. It was not about separating the left and right hemispheres of the brain, but, strange as it may sound, it was about synchronizing the juxtaposition. A rare encounter that definitely deserves high praise."
and
"The unbridged music energy and power balance continued into the low-frequency response, where the Leviathan not only maintained the low-frequency content with authority but also enhanced the spectral sound quality due to the Pysho acoustics (proper lower foundation extends the upper ranges). Not in an artificial way, but in a fatigue-free, natural way, while guilelessly emphasizing the micro and macro details."
Are all of these incredible audible outcomes simply achieved by "filtering out" RFI?
REVIEW of Stage III Concepts Leviathan Power Cable here.
Or are we not discussing the effects of "high-end" mains cables any more....
Almost all can be handled by good design and good designers and many of the problems are abetted by problems in the wall. Lots hum issues threads at ASR.
Just write an article if you are not satisfied with some explanations found on ASR on some aspects.
Be sure to include all aspects even the ones that you have not experienced or encountered yet.
Hum and 'ticks' from other gear can be very annoying and are not always easy to trouble shoot.
This is the main reason why not everything is always covered.
I have tried to explain a few aspects (on my website and here) but it is never complete.
One can't make it too technical but also not too simple.
Please refrain from contaminating topics with the 'common noise' of ad hominem attacks and casting aspersions at others .
But, if you do with to make a an appeal to authority in the EMC area, are you iNARTE certified for EMC?
That really was not an ad hominem. It wasn’t clearly directed at you either.
