Where are the subwoofer builds ?
Marc v E
The Netherlands (Holland)
Given that a sub has a massive impact on the perceived sound, that we need multiple of them, which usually isn't exactly wallet friendly and that their looks...are an acquired taste, why don't we see more dyi subwoofer builds?
Here is one for example
I simply bought the Parts Express 3ft^3 box:
and the RSS390HF-4 woofer:
to go in it.
OK, I added bracing, mostly for OCD.
I'm currently doing my first speaker build, slowly and crudely. Two 18" Dayton subwoofers from Parts Express.
knowledge on drivers and design, equipment to build etc ?
I have 3 JBL 4645C that got way cheaper then i could have built them myself
That is also a reason
Subwoofer made from a cardboard tube, featuring dual 12-inch JBL drivers in a down-firing configuration. Plus one of two bass enclosures using the Peerless SLS 10 driver. A good driver—low price, but a weak motor and low power handling. In my opinion, you need several of them.
Messy setup, mostly for testing purposes:
The main reason for me: cost/performance wise, An SB1000 is hard to beat once you factor in amps and DSP.
Are you asking why there aren't more out in the world?
Or that you'd like to find forums where they are discussed more?
Link to a post I made in the thread below. (My post is not the preview shown in the link)
Does anyone have experience with these kits:
  • Seas L26ROY 10" Powered Subwoofer Kit​
  • Scan-Speak Revelator 26W 10" Subwoofer Kit​
  • CSS Audio SDX10 subwoofer kit​
I have built my last several subs. When I suggest it to others often its they don't have space/tools for such a project or the time. I wonder if there are more diy subs than speakers, tho....
Both theoretically and practically :) , I believe a subwoofer is simply a box with driver(s). I see no need for built-in amplifiers and use external ones. And a single external processor for the entire system.
One don't necessarily have to cut the plywood himrself; one can order the boxes from a workshop.
We are discussing home subwoofers here, right?
Two more points to discuss:
In a typical home system (I neither like nor use desktop systems), the result depends significantly on the room's transfer function and may differ from the anechoic frequency response.
Significant LF compression\limitation (often found in mass-market subwoofers) does not meet high-fidelity standards.
Well, the box can be simpler or more complex and with different general design philosophies.....
IMO never wanted to build an amp into any of the subs I've built, external amps are my preference. Single processor for setup for sure, hopefully it's capable as is your patience :).
I have cut my own panels from bigger wholesale ones, but if I could just go to my favorite supplier and order great cnc ready to go panels, well I wouldn't get too upset that isn't gonna happen :)
Mine are made from scraps of material from work (CPUed baffles) and unwanted furniture.
https://www.audiosciencereview.com/...lain-wave-radiation.24396/page-2#post-2504475
An audiophile acquaintance of mine, however, ordered some very beautiful ones from fine woodworkers after much discussion. Its enclosures are far, far more expensive than the 21-inch B&Cs installed in them. But he never did manage to get decent sound out of them. I think he sold them to someone; I don't know what became of them after that.
Here's mine.
Had them over 15 years!
Thanks to Volvotreter and Cowanaudio and the Colborative taped horn sub project thread on Diyaudio forum - excellent stuff.
I chose to use my Eminence Kappa PRO LFRII's, they had been in a pair of Tannoy GRF cabs before with HF horn on top - nice drivers and they modelled well in Hornresp.
Design
2.4m tall / long.
Hornresp
Drivers
General construction
Finished one
First in room measurement
Used DSP to tame.
Here's a measurement of the Tapped Horn Sub and Mid Bass Horn playing together
The pair fill a large room no problem, but can be used in smaller spaces and controlled effectively.
I now use them upto to 60Hz only..
They really excel not having to go up to 90Hz..
It was a fun project and they have been the things that have lasted all the way though my DIY horn hifi journey.
