For over 30 years I have been running 50 feet of speaker wire because my amps, computer and DAC were all at my desk and speakers at the other end of a 30' room. Things got even worse when I switched to an active XO for my 3-way speakers 15 years ago and I had 7 pieces of 50' speaker wire for the 6 drivers + a sub on that end of the room. Even though I was running 12 gauge wire to the speakers I knew this was less than ideal. A couple years ago I scored a 50' 8ch XLR snake at a good price but had been putting off the chore of relocating the amps, ripping out cable and routing the beefy snake.
Well, over the weekend as a birthday present to myself I decided to dive into the project along with a phono cart upgrade. This is purely subjective because I have no way to ABX this obviously but WOW, quite a difference and I'm able to achieve a higher SPL than previously as well. Even though I used heavy speaker cable and it was routed in parallel it ran next to other AC cables and, until recently, some florescent fixtures. As of now, none of my speaker wires are longer than 9' - that 40' of added impedance wasn't helping anything that's for sure.
A shielded line level signal is nice and clean by any comparison. Not the fastest or easiest tweak I've ever done but a solid one for sure. Now to give the amps a little more airflow and some cable wrap is already in route to my door. Yup, big speakers, not pretty.
edit: To close out the thread hopefully - the change in SPL is attributed to swapping amps on the tweeter channel. Previously was using a Topping PA3 with 19dB of gain on balanced connection and now using a Hypex with 25dB of gain. I misread the 4pt type on the Topping spec sheet and saw the 25dB gain for single ended. Since I'm doing an active crossover things like individual speaker gain and amp gain are controlled in software. However, the whole point of the thread was that line level runs are better than speaker level runs in pretty much any situation.
