Whilst I understand and accept that the Panther is a crude cypher for the conclusions of a detailed test report, it nevertheless is the 'headline' for the report.
It's not the Panther I have any issue with, it's the conclusion that just because something can be so much better technically, the one being considered is somehow faulty/sub standard/useless, whereas it may be fine, just not as good as it might be.
I have two examples of this, the Amazon basic amplifier and the Behringer A500 amplifier. Neither are anywhere near SOTA, neither are anywhere near as competent technically as others, but equally, both are perfectly usable, likely to be transparent in normal use, and so are perfectly sound choices where the performance is deemed adequate. I have no need for anything better than adequate, anything more than adequate is an unnecessary indulgence, although my definition of 'adequate' may be different to others'. If it's transparent under the conditions of use to which I will put the item, then what need is there for anything 'better', and certainly more expensive? I have no use for 'nice things', only what works. Others of course may have different criteria for 'adequacy' Some seem only to want 'The Best' regardless of whether it works any better, I'm not one of those.
S.
