Frank, you have no idea how fascinating this thread is.
Ditto!
I have an old Garrard in the closet...
Like this one:
Most of the turntables made whilst I was there were inexpensive but IMO good for their price.
The little clip in cartridge carrier, for example, gave a less peaky output from the cartridge than an SME type at many times the price.
The top model was the 401. It was a carefully engineered heavyweight for pro use.
I remember at the time it was £72 and the Linn LP12 was £300. The Linn probably cost 25% as much to make as the 401 but back then Garard worked on cost + 10% margin, whereas I am sure Linn were basing their price on what people would pay.
The 401 had always been made in batches on the production line but sales had dwindled and so the assembly was put into a room where a skilled lady hand built each one. The guys re-costed it and worked out a new, inevitably higher, price and sales volume shot up again.
The power of more expensive = better.
I think your photo pretty much sums up Garrard's problem. First, make no mistake about it, as a turntable company they most likely would have gone under no matter what they did, due to digits. But even before that happened, the company was mostly tied to the record changer. Sure, they made the 301/401, but I don't think it was ever exported in significant numbers to the US, and they certainly never advertised it. We had a couple of Garrard dealers in my mid-sized town, and none stocked it.
Everything except the motor and electronics was Garrard. There was no electronics manufacture there.So when was the decision made to introduce direct drive turntables? The DD-75 sure looks like a Japanese DD motor unit with Garrard electronics, but with a big solid platter.
I have no idea what the Garrard importers into the USA (I assume you must be USian) prioritised, but here there were practically no record changers being sold by Garrard. All the popular decks were single players, though some had interchangeable long centre spindle with a mechanism and a pop-up support so they could be used with a stack if the owner so desired. My first one (SL75) had this option but I never took it out of the box and only used it with the standard short spindle.One last thing about the pantograph arm, which as I've said is a genius design, IMO. Garrard actually updated the design, creating a magnesium alloy, lower mass version. I don't know if they did that in-house, however I have no reason to think that it wasn't an improvement over the original arm. But what did they do with it? At the time when everyone and his brother was moving away from record changers, they put the new arm on--you guessed it, a record changer. And it was not just any changer, it was probably one of the ugliest changers Garrard ever made, from an aesthetic standpoint. I mean, it was as if this company was just looking for excuses not to go under.
My first hi-fi store experience was at a retailer that sold Garrard. I think this was around 1970 or so. I'd never been in a real hi-fi store. The place had the line of Garrards in their window. From the lowly Model 30 (I think it was called) to the SL-95, with the wood tonearm. I walked in and they featured two particular models in their 'supreme' system. One was the Pioneer PL-61, and the other was the 100. I'd never seen anything like those. I could only afford a Garrard Sl-55. Then I bought the Sl-72. Then I bought a Z-100. Then a ton of other turntables from other manufacturers. You know how it is, as a gearhead. Still use a 100, which does one thing better than all my other tables. Also have two other DD models I never got rid of. But the Garrard got me started on the road to hi-fidelia.I have no idea what the Garrard importers into the USA (I assume you must be USian) prioritised, but here there were practically no record changers being sold by Garrard.
That is very old version of the support for the record stack rims for the auto-changer.What's that vertical doohickey in the back left corner?
There were several possible autochanger mechanisms over the years though there weren't any new auto-changers being designed when I was there.
Assuming it works in a similar way to the later ones, the bend 'spindle' is static and attached to the chassis. At least that's how I remember it - ot's been a few years since I've seen one close up.So that must be why the spindle is so long and bent at the top?
That would seem to lead to wobbling...
The spindle doesn't rotate on an autochanger. It does mean the thrust bearing is a ball bearing rather than a single point. I would imagine there is a video of an autochanger working somewhere.So that must be why the spindle is so long and bent at the top?
If you choose to use the auto-changer feature:
The tall notched bent stationary spindle will hold a stack of records.
The entire doohickey moves in an out for different record diameters, and supports the edge of the leaning stack. The little arm with the wheels is spring loaded and presses down lightly on the edge of the stacked records
When it is time for a record to drop, the doohickey has a little finger that pushes against the edge of the bottom record on the stack, encouraging it to fall down past the notch in the spindle.
View attachment 30620View attachment 30621
It usually worked, but not 100%.
I usually didn't use it, as it was not mandatory.
Seems like the spindle pulls out, and a short straight spindle was also provided.
When we tested Mobil 1 against the Valvoline racing oil we had been using we found we could run the engine hotter without loss of power. Smaller radiators and ducts was a significant loss of drag and more downforce too since less of the flow was being diverted.All of my 1980 vintage Mobil 1 got used.
I have old LP boxed sets of classical works with the sides cut like that for use on an autochanger. Confusing for the unsuspecting!My first HiFi (monaural) system (1958 - I was a 16 y/o HS student) included a Garrard changer like this one:
At the time, as an only child, I lived with my adopted parents in a two bedroom bungalow on Chicago's south side. (Modern Google picture - hasn't changed much since 1958)
My parents owned a Stromberg-Carlson console HiFi (the Fi wasn't very high) with AM/FM/SW radio bands, turntable - I remember it as being very much like this one from an internet picture...
...and they owned a few 12" monaural LP's, and a couple of "albums" of 78rpm classical music "records" like this one:
78rpm record sets (albums) came with, for instance, "sides 1+8, 2+7, 3+6 & 4+5 respectively on four disks, so you could load an album stack on the spindle and listen to sides 1, 2, 3, and 4, and then remove and flip the stack, and listen to sides 5, 6, 7, and 8. More on 78's HERE.
And now you youngsters know where the term "record album" came from. I find it fascinating that the terminology survived to indicate any collection of songs on any medium from LP to analog tape to CD and even digital media that contains a collection of songs that is analogous to a binder full of 78's!
I wonder if the short length of many popular songs is related to the approximately three-minute max available on a 10" 78rpm monaural record. A lot of pop music 45rpm records were less than three minutes long. Then again, the term "albums" also survived into the internet/digital storage age.
