When Dirac ART to PC?
Can't answer your Q, but if I were a PC user interested in ART I'd probably just look at Room Shaper instead. Dramatically cheaper, although a bit more work to setup.
Try this! https://umamiaudio.com
We also use MIMO technology to use surround speakers / subwoofers to physically cancel out room echo.
Hello, I have seen your website and it looks impressive. My understanding is that MIMO and DBA technology are fundamentally different with only DBA actually using cancellation for room decay and MIMO using an advanced type of multi speaker EQ to do the same. Can you clarify if your product actually uses cancellation to improve room decay like DBA or something else.
Thank you.
My product actually uses cancellation to improve room decay. You can use all of the speakers in your system at once. You can also join us on discord! https://discord.gg/fUGUVQDc
Thank you.
