- Joined
- Dec 9, 2020
- Messages
- 371
- Likes
- 743
While doing some voltage calibrations today, I found out that the positive and the negative end of a balanced output on my RME Fireface UC do not output the same voltage. I measured 1.9V on one lead and 1.3 on the other (don't remember which was which, but I think the positive had a higher voltage).
I then recorded from both wires and also recorded a differential signal (which should sum to zero if I understand that correctly?).
Negative: -18.4dbFS; Positive: -15,9dbFS; Sum (Positive->Positive, Negative->Ground): -11.6dbFS
Signal generator was REW in ASIO mode, 1khz. Here is the waveform of the measurement across + and -
Am I missing something? If I understand the differential nature of balanced connections correctly, the signal should be mirrored, which should sum to zero, or just be twice the voltage of the individual channels, when measured differentially (since they should output the same voltage?).
