Did you check how that looks in REW? Phase shift might work better as you can control it more granularly to achieve the right balance. Also, if you have 2 subs, you might want to have one in phase and the other one out of phase. But also you might have just gone lucky and stroke the gold with the first tweak.ALL SUBWOOFER OWNERS — PLEASE READ THIS
Over the last week I achieved more progress in aligning my subs with my mains (and rear surrounds) than I had in the previous five years.
And I’ve tried everything: Audyssey MultEQ-X with custom PEQ filters, REW with a UMIK-1, different crossover frequencies, different phase settings… you name it.
But this week I did two major things:
1) I inverted the polarity of my subs from positive to negative in the SVS app.
Turns out this is not the same as applying a 180° phase shift. (If in doubt, ask AI why.) My Revel F208 speakers and subs were aligned in positive polarity when running full-range, but not when crossed over. Again, ask AI why a crossover often introduces an effective 180° shift (roughly +90° on the speakers and –90° on the subs). After inverting polarity, the sound improved A LOT.
2) I plugged the ports on my Revel speakers when crossing them over to the subwoofers. This also made the sound noticeably cleaner. I “lost” around 2 dB of bass between 50 and 140 Hz according to REW, but AI says that I am “not "losing" 2 dB of bass. You are successfully removing 2 dB of resonant, slow, boomy port bloat”. Like I said it definitely sounds cleaner and I am not hearing any less bass after plugging the f208 speaker ports when they are crossed with subs @60Hz.
I cannot begin to describe how much the overall sound improved. The bass is super tight - more massive but never overbearing. Just pure joy. (Of course, I still used PEQ on individual speakers, but I had done that before too.)
P.S. Audyssey cannot and thus will not flip subwoofers polarity for you even if needed, so that was the reason I was stuck. But AI says that Dirac Live Bass Control (DLBC) does this, and “it's the entire reason DLBC is a "magic" technology”. Or you can save a few hundred bucks and do it (at least try if you haven’t) like I did: manually.
(It’s kind of bewildering now that I see the effect to think that after so many years and so many millions of AVRs sold Denon have not incorporated this simple test for subs polarity in their auto calibration - which way subs play better with main speakers - and will rather do insane things like putting crazy distances to subs to try to compensate for polarity, and as an effect will create more problems and solve none)
If this helps your system as well, feel free to donate a like or something!![]()
I would not ask AI anything complicated though. If feeds from forums mostly where people post all kinds of stuff and then you have AI hallucinating on top of that. Example would be that losing bass between 50 and 140hz should have nothing to do with the port on your Revels. They are also not so big to be crossed at 60hz - unless you have some humongous room gain. My 2c...
