MiloTheFirst
- Joined
- Jul 11, 2020
- Messages
- 37
- Likes
- 27
I understand that for Amps normally as one increses the voulme and demands more power distortion will worsen, but I don't know how they are supposed to beheave as the knobs goes the other way and we start reducing volume instead. in fact, most amps don't even indicate at what point in their knob they start amplifying in a direction and attenuating in the other.
For DACs I have read in this forum a couple times that they are suppoused to work at their best at full output capacity.for me, this statement seems counter intuitive to conventional wisdom, normally any machine will shorten its lifespan if continuously operated at full capacity. I am not saying the statement is false, I can not tell either way myself, I would just like to understand the engineering principles behind it in order to accept it as something more than annecdotal advice.
I have become curious on this topic as I am facing the following situation, my system (Tempotec Sonata HD Pro + Topping A50s + HD660s) has a lot of headroom, I listen with the DAC set at 66/100 (in the windows volume interface) where it delivers about 1V (half its max output), and the knob of my amp is normally set pointing at 11 if it were a clock, never needing to be pointing higher than 1 o'clock.
With my current knlowledge I don't know if the system could be working at its best performance by turning up the DAC and down the Amp, the other way around, or any other point in between. any feedback is apreciated
