The cable doesn’t directly make equipment off but it damage over time, can be a year or months. As always, it’s related to reliability issues. Especially the interconnect cable.Then they aren’t just bad, they are broken.
Well I did have an issue once. RCA, cable lost connection with ground resulting in huge hum levels. As I was using bridged Classe 25's (about a kilowatt per channel) it damaged the woofer somewhat. Of course I was using my own custom woven pure six nines silver with pure teflon insulation interconnects. It was the damn WBT locking RCA jacks that did it. Cuased too much physical stress and caused the issue when some basic non-locking RCA's would not have. The Classe amps had XLR input, and if I had a balanced preamp I would have used those. Had I used the RG6 RCA RGB video cables leftover from the cable company cable box all would have been fine. Anecdotal proof that silver cable sucks and is dangerous.For sure bad cable can damage your equipment. Not just better or same quality sound heard but hurt your stuff.
Without anyone noticing in between that there is something going on? No way! How would that even work? The only way a cable can damage is either by a short or open circuit, and both are immediately noticeable. Give me one real-world example of this happening?The cable doesn’t directly make equipment off but it damage over time, can be a year or months. As always, it’s related to reliability issues.
@JktHifi I'm wondering about this as well.Without anyone noticing in between that there is something going on? No way! How would that even work? The only way a cable can damage is either by a short or open circuit, and both are immediately noticeable. Give me one real-world example of this happening?
I've seen where the solder tabs or cups are located the shorting occurs there. Especially when the tabs are flexible and can be forced into the other conductors tab.I guess an interconnect could short the signal to ground and that might damage a device's output. I personally have never seen a reasonably well-built cable go short but going open is not uncommon, especially when handled regularly and improperly.
How can it be scientifically tested when the two metals have different resistance? Can you do such a comparison please?
Silver is about 7% more conductive than copper.
Silver just looks more pure than copper.
Copper is very cool in that it has been recycled for thousands of years.To me, copper is the sexiest looking metal. Its only flaw is that it tarnishes relatively quickly and starts to look dull.
Or even a heck of a lot thicker. Thick zip cord just doesn't cost that much.Given the relative cost, making a copper cable slightly thicker would be far more economic than using silver.
I can see that happening, especially in cheap connectors. Usually, I use heat-shrink on each wire (including any tab) at the joint. Reinforces the connection as well from mechanical separation.I've seen where the solder tabs or cups are located the shorting occurs there. Especially when the tabs are flexible and can be forced into the other conductors tab.
Agree!Another mish-mash of mixed arguments that go nowhere. You don't understand the subject. You base your opinions on uncontrolled listening and what I would call undisciplined reasoning. And tell the engineers to go figure out something that agrees with your opinions. That is not a good path to get anywhere toward new knowledge.
Oftentimes whole ohms.I bet a lot of the exotic silver cables get used with tube amps, where the output impedance is a few tenths of an ohm, or more.
I have cables I bought from amazon, I have $250+ self made cables with the stupid crisscrossing from that guy on youtube, and I have $200+ cables that allow biamping (bi-cabling? who knows) from aliexpress.
Do cables matter at all? Should I just stick with my $50 / 50ft spool of Amazon cables (I think they are 12AWG)
I swear I can hear a difference but I can also see that difference in my face, so I don't trust myself.
