jcarys
Have you tried taking that 20-25 cable out of your setup, and checking the same sub with a short cable? That would be the first item I would want to test for hum. It's possible you just need a better shielded cable.
Sure - but do you have the measured figures for an amp we may know of? It's interesting to some of us!A tube- or transistor-based analog power amp. No controls/processing.
Class-D power amps begin to introduce some but still negligible latencies.
I do not because it is rare that anyone is concerned with it.Sure - but do you have the measured figures for an amp we may know of? It's interesting to some of us!
It does have some controls but, imho, they are minimal.Or does your unpowered sub have DSP controls included?
that's an excellent idea. I did use a 2nd cable since, it's also a long cable, and it's the same result. But I can dig out a simple 6 ft. cable and see if there is any difference.Have you tried taking that 20-25 cable out of your setup, and checking the same sub with a short cable? That would be the first item I would want to test for hum. It's possible you just need a better shielded cable.
1) currently, I just own an old Yamaha AVR. I got it at least 7+ yr. ago. Prior to that, is a Sony AVR ES series, that unit dies after 19 year.I am also confuses by the OP's imprecise writing.
OP, which exact component models do you already own?
Do you really not care to fix your ground loop hum? That might not cost much or even zero.
Which exact models are you considering adding?
The fact that the sub output is at line level rather than amplified does not matter to the signal processing, you just need to add an appropriate monoblock power amp.
At 1000W RMS a good one will be more expensive, so you need to give details to determine how much power you actually need so as to not waste money.
Now, does your Denon have DSP controlling the line level sub out?
If both, then we can figure out which to choose, don't use both.
www.sct.com.tw
1) sub-woofer w/ XLR, now you are talking and that's a great idea. I just check those top 2 models from Focal, their sub-woofer doesn't have XLR option. As to AVR, you are absolutely right, Denon A series high end XLR does have balanced out.
2) I am always in favor of European brand name speaker, so I just have to do some research and see what other EU brand that has sub-woofer w/ XLR.
as to the
Behringer NX6000
even the Focal active sub-woofer is only 600W, why would we need a 6kW power amplifier?
You have to check that the hum is not coming via the RCA cable. You could have the same issue with a passive sub and poweramp then. I don't think it's that, more likely something with the power. But before actually buying something expensive - check.5) did try to include the powered sub-woofer in the same circuitry as the AVR in my room, and also did try to have the AVR and the power sub-woofer in 2 separate circuitry (current setup). No difference, both setup yields the humming sound, this is why I lean on a passive sub-woofer in the future.
I re-think about what you talked about, it still won't workA passive sub will just have speaker wire inputs. It *is* odd that these Focals need that "power supply". It seems to do some DSP work.
The XLR cable will go between the AVR and the amplifier (all these pro-audio amps have XLR connections for the inputs).
Yes, that Behringer NX6000 would be overkill. Behringer makes a 1000W version, NX1000.
I bet your sub is just fine. I'd address the issue with the sub you have.
You've got some good suggestions so far and some links to some good articles. Before going down the rabbit hole of fixing it, I'd try and verify that is is indeed a ground-loop issue. Have you tried just unplugging the subwoofer audio cable from the sub, at the input to the sub itself? Remove anything connected to the sub except for the power cable. With the input removed and the sub powered up, does the hum stop? If it stops, you have a ground-loop issue. If it doesn't, then something is wrong with your sub.
