Music itself, actually.If the "musicality" isn't coming from the things that are measured, where is it coming from?
Don't see exactly what any Audio gear would have to do with it.
this is common mistake for audiophile. the role of the gear, or gears is to reproduce the music as close as it was originally/intentionally created. it is not to add colors to it, not warmer, not brighter, not whatever. that's what EQ is for.Guys, I wrote:
"If you're looking for the best measured values, then the Topping LA90.
But measured values aren't necessarily musical.
Personally, I love my Musical Fidelity David (25W Class-A) on 2-way Dynaudios, or rather the resulting overtones."
This means that best measured values (e.g., a SINAD of an incredible 120 dB! with the AL90) don't necessarily have to sound good. The Musical Fidelty A1 / David 2 I mentioned is a case in point; it has mediocre measured values but "sounds" fantastically musical. Perhaps this is a statement only people who are musical themselves understand.
The approach that a good hi-fi system should be as completely neutral as possible in your system (with regard to the usual measured values) often doesn't work in my experience. Music reproduction in a private environment is always a highly subjective matter. I can only recommend everyone to listen to a Class A amplifier, for example, and then judge what sounds "good. And of course, that doesn't mean you have to like it."
Actually, It's a statement that only people who know the effects of sighted listening, and the meaning of amp measurements understand.Perhaps this is a statement only people who are musical themselves understand.
The other way around, musicians understand that gear is only important so far as it helps them express their musicality. And that's much more about actual instruments. The monitoring is much less important, a good musician can make do with what's objectively awful crap too.Actually, It's a statement that only people who know the effects of sighted listening, and the meaning of amp measurements understand.
Opinions vary to some extent. As for my opinion, I own the following:Which AMP is currently the strongest contender?
Hello,
I wanted to ask what's hot right now in terms of amplifiers in the $1,000 price range?
For sure, of course even amps can be creative tools if they have a lot of distortion...The other way around, musicians understand that gear is only important so far as it helps them express their musicality. And that's much more about actual instruments. The monitoring is much less important, a good musician can make do with what's objectively awful crap too.
One of the few occasions where transistor vs tube really matters.For sure, of course even amps can be creative tools if they have a lot of distortion...
You might want to quote what you are replying to. Just hit the reply button - or select specific text in the post, and hit reply next to the selected text.No the "trick" is to understand none of that is audible amongst SS amps ( or at least cant be identified with a legit listening test) so its moot
The caveat is modern quality solid state amps. In that regard, some of the budget class D amplifiers have load dependency that may be audible to some people, especially those that still can hear all the way to 20kHz.No the "trick" is to understand none of that is audible amongst SS amps ( or at least cant be identified with a legit listening test) so its moot
WiiM Mini with digital optical into Yamaha A-S701 or 801. Plenty of juice for your speakers and room plus awesome features and knobs. That's an amp you can enjoy.I'm actually looking for an amplifier, or possibly an amplifier with a DAC. For a small room (about 20 square meters) and bookshelf speakers. I can buy the DAC separately (I was thinking about the FiiO K13 R2R, good enough?) and the WiiM Ultra as a streamer. Could be class D.
You made me lol. It's like that sometimes. Besides nihilism it can also be pedantic. So thanks to you I told OP get a nice Yamaha integrated. Ah, that loudness knob – that'll be so satisfying.Oh my god.... OP just wanted some recommendations for devices to look into and of course it devolves into the typical nihilistic ASR drivel of "nothing matters anyway you know"
To which the answer is easy. Buy one that doesn't have the load dependency. It's fairly easy - and one of the prime reasons @Amir does all the measuring - so we can make informed decisions.some of the budget class D amplifiers have load dependency
You mean like this?You might want to quote what you are replying to. Just hit the reply button - or select specific text in the post, and hit reply next to the selected text.
