If there is a new game changer every 2-3 months, is anything really a game changer?
You will find that the founder and main reviewer of this forum will consistently repeatedly say that certain non-ideal measurements are below hearing and thus inconsequential, with a good panther rating given as long as the product is worth buying over alternatives. Audio is a solved problem in general. So once you have enough budget to solve the main problem (usually power and connection), you use the rest of the money to solve your specific problems or preferences. Take amp class for example, my home is scattered with low-power class D for the TV etc. But my main and room/computer amp is a 10-year-old 45Wx2 class AB running 24/7 with the computer sitting on the top panel without the need to worry about longevity like those *certain popular high power good value amp that triggers the forum when mentioned* and I'm keeping it that way partly because of the 7 relay-switched inputs and 2 relay-switched outputs which make life a breeze together with the remote. It does 80dB SINAD and I don't hear any noise with my ears pressed up against the tweeter, so that's good enough.
With today's technology and with speakers like Usher S-520, an amp with DSP to fix the speaker's bass response is going to elevate the final result more than having gold-plated capacitors. Room response is also a required fix anyway even if you spend infinite money to get the perfect speaker and amp. So with that budget an amp or DAC with DSP is what I'd recommend for a start. Then adjust the final price with required power, connection, other features, preferences.
@solderdude,
I am a little surprised by your answer. Yes, audio sound is a personal matter, everyone likes something different. It is difficult to please everyone with one amplifier.
But tests indicate models that have, for example, less distortion, better SNR, are better made, have better functionality, are better designed, etc.
In this way, you have undermined the meaning of this (and many other) audio forums, as well as the editors who test the equipment
I know I may have asked some difficult questions, but there have always been favorites in every price range. Three years ago, as I wrote, the SABAJ A30A stood out from the rest, with almost everyone recommending it.
