What would y'all recommend to someone wanting to buy an extremely neutral, closed back, wired over ear pair of headphones that's close to $100?
blud123
i'm posting this to just a few forums but I'm looking to replace a Logitech G Pro X that i had and i really want a super neutral sound and I really would love something that is around my price range and is of good quality. If anyone has recommendations I would greatly appreciate them!
AKG 371 often receives a recommendation
I'd also say Moondrop Joker although it has some increase in the treble but I'm not sure at which frequency
Shure SRH440:
Please note that there's a new version called SRH440A, which is less neutral with a big bass shelf:
Here's the same frequency response data, but better aligned with the Harman OE2018 target to more clearly show the SRH440A's bass shelf:
For neutrality, you want the old SRH440.
Howdy. Welcome to ASR.
I agree, your best bet will most likely be an IEM, if you do not have issues with the form factor. Moondrop, Truthear, 7Hz...
AKG 371. With two caveats: the cable is annoyingly microfonic and as a closed back headphone it gets warm inside (especially at summer) after a certain time of use. But on the other hand it sounds very good without PEQ (own it myself) and with Amir's recommended EQ it sounds even better.
